euro connector on plasma cutter
发表于 2021-8-31 23:00:51 | 显示全部楼层 |阅读模式
HI I have a question for those that have a plasma cutter with a euro connector.Will you look at you connector and tell me which pins are used on you connector.there are 9 pin locations around the large center connection. Mine has 4 small pins (of the 9 used) and those are the ones I am interested it. just the positions only.ThanksTom
GMT+8, 2025-12-28 17:58 , Processed in 0.096263 second(s), 18 queries .
