Tigging Tube Question
发表于 2021-8-31 23:00:47 | 显示全部楼层 |阅读模式
New to me, beginner with the tig. I have just started to attempt to tig up some test joints with some 1.25 crew .065 tubing and would like some input on the issues I am finding one is the nipple bump where I stop, and the rest I think is just manual technique "I need to get down the movement and stop when I cant see well enough". But please have at it with all you've got: With the niple I taper peddle and if I dont i seem to get a cratered bump like the bottom photo.Arcmaster 185.1 pre flow6 post flow20 amp hot start90 amp20 cfh1/16 ero7s21/16 rare earth tungsten pencil point tipLast edited by nikodell; 11-25-2012 at 10:55 AM.
Reply:Looks like you need to clean the steel, lots of stuff floating in the weld. Was the steel coated? And yes, you need to back off the pedal slow to keep from leaving a crater sometimes you need to add a little filler as you back off also.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:I don't tig much but when I've tried thin stuff I use rod that is thinner then what I'm welding on. The rod your using now takes the same amount of heat to melt as the tubing and to melt them both at the same time requires even more heat.Your tubing is .065 so maybe you should try using .045 rod. That all I got.
Reply:That's a very difficult joint what you have over there, first cover the basics, that would be vertical and horizontal position.Don't see anything wrong with the settings and setup .Work on torch angle and arc length ....--------------------------------------------------------------www.becmotors.nlyup, I quit welding.. joined welder anonymous
Reply:I think you did a great job.  Alot of beginners have no appreciation for how difficult tubing is to tig.  Laying beads on flat plate is no comparison to having to constantly adjust your angle like you have done.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Its all tough if you don't practice. Now that  its cold again I am doing at least a few minutes every day.  Just figured out I need a new reg so I am going to get a flow meter, seems this victor can be turned down on the output to almost nothing and I still have enough argon, the cylinder was gone quick before I figured it out.
GMT+8, 2025-12-28 17:57 , Processed in 0.158027 second(s), 18 queries .
