miller syncrowave 180sd or thermalarc 185tsw
发表于 2021-8-31 23:00:43 | 显示全部楼层 |阅读模式
i have a millermatic 251 with a spool gun but have some projects coming up that i need to go thinner aluminum than the spool gun will do so im gonna get a tig.  ive heard alot of guys like the TA because of the incredible adjustability but im kinda leaning tward the miller due so simplicity. im not a welder by profession so im not using the equipment everyday.  although i may get my welding certification to weld electrical bussbar cu and al.  im an electrician and run into this more and more lately.  so what do yall think???
Reply:ok now i have realized im comparing apples to orangesmiller dynasty 200 or TA 185TSW  hmmm or do i go with the tried and true buzz box transformer welder of the syncrowave???im just wondering if the inverter tech is going to be that much of a differnce.  i kinda like the portability of the inverters.
Reply:Originally Posted by barebackjakei have a millermatic 251 with a spool gun but have some projects coming up that i need to go thinner aluminum than the spool gun will do so im gonna get a tig.  ive heard alot of guys like the TA because of the incredible adjustability but im kinda leaning tward the miller due so simplicity. im not a welder by profession so im not using the equipment everyday.  although i may get my welding certification to weld electrical bussbar cu and al.  im an electrician and run into this more and more lately.  so what do yall think???
Reply:I have the TA 185 and I love it.  It will do the light stuff.  Pulse could help by putting less heat in the base metal.   All those adjustments do make a difference, but it took me a couple of weeks to figure out what does what.DavidReal world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-28 17:57 , Processed in 0.121955 second(s), 18 queries .
