Orbital welding on thin duplex tube
发表于 2021-8-31 23:00:41 | 显示全部楼层 |阅读模式
When tig welding in the vertical up position what adjustments should be made to avoid the weld looking like a turkey's neck. Amprage? Wire speed? Technique? Travel speed?
GMT+8, 2025-12-28 17:59 , Processed in 0.109319 second(s), 18 queries .
