Pouring a babbitt bearing
发表于 2021-8-31 23:00:35 | 显示全部楼层 |阅读模式
Hi Everyone: My son, Will and I received a $6000 proposal to rebuild our turbine main shaft bearing. We decided to do the job ourselves. This is how we did it: http://frenchriverland.com/index.html I hope you and your families are healthy and prospering!! Sincerely, Bill Fay
Reply:Great read as always. Keep up the good work.
Reply:Originally Posted by forhireGreat read as always. Keep up the good work.
Reply:Interesting process Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Bill, you and your clan do some wild and crazy stuff."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Great work.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Originally Posted by frenchriverlandHi Everyone: My son, Will and I received a $6000 proposal to rebuild our turbine main shaft bearing. We decided to do the job ourselves. This is how we did it: http://frenchriverland.com/index.html I hope you and your families are healthy and prospering!! Sincerely, Bill Fay
Reply:As always Bill, an excellent read, thank you......Mike
Reply:Yikes, that's some project! That's great info, I've never seen a Babbitt bearing poured before, you guys are fearless and make it look easy. On top of all the work, the research for maintenance and upkeep must be mind numbing, too. Thanks for sharing  When a welder tells you to "stick it", what do they really mean?"In a time of universal deceit, telling the truth is a revolutionary act." - George Orwell
GMT+8, 2025-12-28 17:58 , Processed in 0.101073 second(s), 18 queries .
