What do I need to start tig welding with my 305g??
发表于 2021-8-31 23:00:33 | 显示全部楼层 |阅读模式
So pretty much what the title say I'm just confused of what I need? Any help would be appreciated
Reply:Lessons.See here. "International Welding Clinic Day". http://weldingweb.com/vbb/showthread.php?t=173851Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:A foot pedal or button...or set your machine to lift start..... High freak box..it comes with a gas valve silenoid ( I know..I spelt it wrong).... Regulator and argon, tig torch. But you don't need the high freak for lift start.Paying the cost to be the boss!!!
Reply:Does the 305g have lift start tig option on it?I didn't think it did.All you need to tig weld steel, stainless steel etc. (no aluminum) is a tig torch with a gas valve, bottle of argon and regulator/flow meter. Scratch start. It's all I use and it works great. Very economical way of tig welding ferrous metals.If your machine has lift start, even better.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:The machine has a tig setting touch start I know I have to get the obvious stuff I just seen some ppl get the inverters an stuff i don't understand why?
Reply:Originally Posted by snoeproeDoes the 305g have lift start tig option on it?I didn't think it did.All you need to tig weld steel, stainless steel etc. (no aluminum) is a tig torch with a gas valve, bottle of argon and regulator/flow meter. Scratch start. It's all I use and it works great. Very economical way of tig welding ferrous metals.If your machine has lift start, even better.
Reply:http://www.lincolnelectric.com/asset...26-5/e6117.pdfWeld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Also is there a wireless remote for the Lincoln's I've seen the one miller has but I don't think itl work on the Lincoln's an I found another one called tru-remote but haven't found any reviews on that one? Anyone know bout that remote like to get into pipeline I think itl come in handy
Reply:Search for my "can I TIG weld off my welder" thread, answers are inside.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Awsome thanks guys for the help not to familiar with tig welding done it a handful of times in school but that was it.
Reply:Originally Posted by 98rampowerAwsome thanks guys for the help not to familiar with tig welding done it a handful of times in school but that was it.
Reply:Good thread. I just bought my new ranger 305g as well.Ranger 305gMillermatic 140 AutosetDewalt Chopsaw2 grindersMy Fists
Reply:Tried scratch start tig welding today. The end of my tungsten tip just balls up. Am i running too hot? Parameters are 3/32" red tungsten, 75 amps, 35 cfh argon, welding on 10 gauge sheet metal.Ranger 305gMillermatic 140 AutosetDewalt Chopsaw2 grindersMy Fists
Reply:I found out what i was doing wrong. I had my tig gun hooked up to positive instead of negative. HahahaRanger 305gMillermatic 140 AutosetDewalt Chopsaw2 grindersMy Fists
Reply:I just saw this. 35cfh is too much. 20cfh is max for a 3/32" tungsten. And that is for a #7 or 8 cup. Too much gas is just as bad as too little.Hooked it up backwards. Done that before.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
GMT+8, 2025-12-28 17:57 , Processed in 0.074359 second(s), 18 queries .
