First student, Mike (Michande)
发表于 2021-8-31 23:00:30 | 显示全部楼层 |阅读模式
So after seeing my offer to share what I know in one thread, Mike asked me if I would help him learn tig...  he came by this am for about 3 hrs....  talked some theory and technique.  Started qith 3/16 aluminum beads with my coaching him. Then onto some beads with filler on 20ga aluminum. Coupons...  here is the result after about 3hrs.    I think he spent 1/2 hr just brushing aluminum Attached ImagesTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Very nice of you Southpaw, I wish I had a coach on my first attempt.
Reply:Beautious
Reply:Nice work - DJ!Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Southpaw was an excellent instructor...  He could have posted many other pictures that weren't very good at all and I am sure I tested his patience at times.  Tig is a lot like the first time I played drums, or the first time I operated a bobcat.  Seems like all your hands and feet are doing different things at the same time.  And if I think about one action I completely lose focus on something else that is equally as important.But like I said, excellent teacher and just an all around dang good guy.Cannot say enough good things about this morning.Thank You.
Reply:Originally Posted by Rick VNice work - DJ!
Reply:Na, na. na, na, nah...  ... if I did come to visit you, somehow I would be leaving with a welder - likely a Big Bad Boy! Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Originally Posted by Rick VNa, na. na, na, nah...  ... if I did come to visit you, somehow I would be leaving with a welder - likely a Big Bad Boy!
Reply:NOoooo shovelon, you don't understand. Ever since I knew DJ he has been trying to sell me one or another of his welders!You just don't know how many Powcon Attacks I had to beat off. Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Nice looking bead Mike!
Reply:Heh. I almost got you to buy a 330Miller recently too.  Oh well someday you will graduate from your TSC triple 110 inverter stackTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Originally Posted by vwguy3Nice looking bead Mike!
GMT+8, 2025-12-28 17:59 , Processed in 0.113766 second(s), 18 queries .
