Wireing up old Miller question
发表于 2021-8-31 23:00:29 | 显示全部楼层 |阅读模式
I picked up a older Miller welder at an auction a couple years back. im just getting to hooking it up now. I have a problem. I cant seem to find an outlet For my Arktite APJ 6375 end. If anyone could give me a link or knows where i could get one that would be great. By the way the welder is a Miller Thunderbolt 225V. The end has three prongs and when i search it the only outlets that come up are 4 prong. Thanks.
Reply:One post...hmm. Well, just in case this isn't spam or a troll, here is the first link that came up on a google search using 'welder plug' as the search term. http://www.millerweldersales.com/pro...product_id=268Personally, I'd just head down to the local big box store and pick up an outlet there...Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:I googled "Arktite APJ 6375" and came up with plugs that run about $475! http://www.amazon.com/Crouse-Hinds-A.../dp/B005GZSQSWMy guess is that this was for a commercial install originally, hence the very expensive connector, possibly for 3 phase or higher voltage power. Not the Nema 6-50P plug I'd expect on a typical Thunderbolt..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Never even thought to look up the Arktite plug...my Lord!  Time to cut the losses and ditch the Arktite for a regular plug and receptacle.Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:If you are going to wire it in yourself, and You really should have an electrician do it,  Just buy a plug and a receptical. for an electric range and install it. with big enough wire. That is not a very big welder and ive run one for years on number four wire with no problems. Mac.
GMT+8, 2025-12-28 17:59 , Processed in 0.323937 second(s), 18 queries .
