Holox cutting outfit??
发表于 2021-8-31 23:00:27 | 显示全部楼层 |阅读模式
Is there any one here that has any experience with the HOLOX cutting outfit (holox is a linde gas subsidiary) the guy at the store said it was supposed to be a Harris outfit with their name on it I am thinking of getting it with 3lbs of welding rod and adding a set of quick connects from proweld that include built in check valves for the hose to torch end then adding later a set for the regulator and hoses any suggestions?
GMT+8, 2025-12-28 17:59 , Processed in 0.094497 second(s), 18 queries .
