Macro testing... what causes a fail?
发表于 2021-8-31 23:00:21 | 显示全部楼层 |阅读模式
just assuming you had a sound, clean pipe weld... clean enough to pass x-ray anyway but failed a macro test.... what would be the more common reasons for this to happen?would exceeding interpass temperature cause this to happen? (by exceed I mean continuously welding as if there was no interpass temp, cooking the metal, etc)or are there other reasons?ty in advance for any information
Reply:Undercut, incomplete fusion, cracks, porosity, undersize, de-lamination of the metal. Basically visual and dimensional criteria.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Originally Posted by shovelonUndercut, incomplete fusion, cracks, porosity, undersize, de-lamination of the metal. Basically visual and dimensional criteria.
GMT+8, 2025-12-28 17:48 , Processed in 0.128495 second(s), 18 queries .
