Range of qualification for partial welded joints
发表于 2021-8-31 23:00:20 | 显示全部楼层 |阅读模式
Hi,I have a question regarding range of qualification for partial joints.My welding procedure (WPS) qualify welding thicknesses range 30-120mm for butt welds.Job to be welded is 20mm partial single "V" from 100mm thick plate in both side. (see attachment).Welding done as per Norsok M-101.Does WPS will be OK to weld for such job?Please advise.Regards,Jaideep Hiray
Reply:what 's this wps : AWS D1.1 , ASME IX , ISO 15607
Reply:as per ISO 15607
Reply:jaideep,the answer is no , but you can create a new wps from your WPQR .
Reply:Thanks denlow60 for your reply. Can I know the reason why the answer is "No"?
Reply:your WPS is CJP Groove Welds and you have to make a weld without root penetration (PJP Groove).You do not have the good weld detais on your wps.
GMT+8, 2025-12-28 17:56 , Processed in 0.079877 second(s), 18 queries .
