radnor welding rods !@#
发表于 2021-8-31 23:00:17 | 显示全部楼层 |阅读模式
a month or so ago my dad had a progect he was working on so he bought some radnor 6011 3/32 rods i went out to the shop picked them up and went to work fixing some welds on a re pourposing project im working on first rod ran great flat welds were fine so i tried some up hill worked great grabed a hand full and started burning them up.....then started having an unpredictable arc (all over the place) any one else have this problem with radnor rods?1979 sa 200victor 100several bfh's several pitbulls (for holding down the floor)
Reply:Originally Posted by texasredneka month or so ago my dad had a progect he was working on so he bought some radnor 6011 3/32 rods i went out to the shop picked them up and went to work fixing some welds on a re pourposing project im working on first rod ran great flat welds were fine so i tried some up hill worked great grabed a hand full and started burning them up.....then started having an unpredictable arc (all over the place) any one else have this problem with radnor rods?
Reply:I have not had good luck with radnor anything. They tried passing off "victor style" torch tips a few years ago at work, never could make them seat right. I purchased a couple 1lb boxes of the 6011 , 1/8", several years ago to try out and ended up throwing it away. I stay away from it now!
Reply:We bought some 3/32 7018 that is complete junk from them. Some of the other Radnor stuff is ok but for the most part I've not usually been impressed. The Praxxair stuff isn't much better. We do have pretty good luck with the ER70S .035 hard wire from them.Whiskey Tango Foxtrot, Over
Reply:The school I go to got some radnor 7018 once instead of Excalibur.  Nobody liked em and a few people failed bend tests. They went in the garbage and we broke out the Excalibur and all those problems went away. Radnor is junk! If you want a good rod buy lincoln
Reply:I've used their 1/8'' cast iron rods, COMPLETE JUNK, couldn't keep a good arc going for more than 2-3 seconds. I only use Airgas for my gas cylinders because they seem to be the cheapest in town and I usually get a good discount "Firearms stand next in importance to the Constitution itself. They are the American people's Liberty, Teeth, and Keystone under Independence." - George Washington
Reply:Another "thumbs down" for Radnor $h!+.   Radnor  mig wire and stick electrodes are a fricking joke!!!!  I wish I could punch out the CEO of Airgas. I would make him choke on that Radnor crap!  I also wish people would refuse to buy Radnor "anything," this putting them out of business or off the market completely.   R-A-D-N-O-R  SUUUUUUCKS!!!!!!Last edited by SuperArc; 03-30-2013 at 11:47 PM.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:A few years back I was given a few sample packs of their equivalent of 6010 5p.  They were ok but nothing I would want to switch away from Lincoln electrodes.  I have never tired any other products from them.  I stick to the same rods and do not switch around.Dan
Reply:It' amazing how different rods of the same number act differently.  I tried many 6011 rods as an experiment, sticking only to the light colored flux brands. I found the 'Airco easy arc" to be almost a mix between 6011 and butter rod like 6013.  There is quite a difference.  I have not tried fourney, but sounds like I will.  Might be a good time to list all the top of the line choices in popular rods.  The expensive super "missle weld rods" and similar ones seem to weld great, but is there a comparable one at a decent price? I rarely use them, but if I'm welding a critical part, sometimes I use them. I tried a higher XXX18 rod just to compare, I believe it was Lincoln 11018.  It seemed good, but I don't have any test results on them.
Reply:Radnor branded anything is usually the cheapest Chinese crap built buy the lowest bidder.    Airgas is really pushing this crap on everyone and its complete JUNK.    They aren't even stocking any of the good consumables anymore.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Originally Posted by DualieRadnor branded anything is usually the cheapest Chinese crap built buy the lowest bidder.    Airgas is really pushing this crap on everyone and its complete JUNK.    They aren't even stocking any of the good consumables anymore.
Reply:This thread has me wondering what my local hardware store (L&M Fleet Supply) carries on the open shelves....For at least 15 years I've just grabbed a fistfull of whatever rod I needed off the open racks - all have welded as expected with normal slag removal.  Normally 7014.Only problem rods I've encountered were last month when I got a box of Hobart 6013 for my kid to practice with - spatters like mad.Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:The Radnor ER70S2 tig rod is ok, and their gloves are fairly decent. Their torch tips are kind of crude looking and their tip cleaners and torch strikers are CRAP!For stick rod I will only buy Lincoln.Lincoln SA-200 code 4816Lincoln Power Mig 180cHobart Hefty CC/CV suitcase wire feederKoike Aronson IK-12 Beetle track burner
Reply:Radnor stainless mig wire and stainless tig rods makes me want to take two weeks off and then quit my job...Last edited by Coastaltech welder; 04-02-2013 at 11:09 AM.
GMT+8, 2025-12-28 17:56 , Processed in 0.094980 second(s), 18 queries .
