Aluminum Coasters..............
发表于 2021-8-31 23:00:17 | 显示全部楼层 |阅读模式
This weekend I decided to make a set of coasters.........The base was scrap 3.5 X 3.5 inch 1/4" steel.......The uprights was some strange hexagonal stuff out of an old paper shredder I used to have and dissected when it broke...... I cut them to 4cm..... (I only had a metric tape measure handy.....).....The coasters are 5052 cut with a 3 5/8" hole saw.........I then worked on the coasters to smooth out the edges because the hole saw made them jagged.........60 grit flapper disc to remove the burrs.....60 grit sand paper on an oscillating wood sander.....  to get the edges smoother.....then....120 grit sand paper on the same sander..... to make them smoother..... then.....400 grit sand paper to finish up the edges....... then......handed them to Ava and asked her opinion....... "That's smooth daddy......" Good enough for me.....First..... pics of the parts all roughed out........(first pic is sand blasted)........ Attached ImagesPrecision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:I got some rubber(ish) shelf liner and some spray on adhesive for the coasters.......Pics of the coasters after the rubberized base was put on..... this was after the 400 grit sand paper treatment and approval from Ava....PICS..... Attached ImagesPrecision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:look great! now get some beers on em!
Reply:Nice, neat idea. Do you have a combination belt/ disc sander ??? That would be one handy tool. After you get it you'll wonder how you did without it.
Reply:Nice job! . . . They look great! Hobart Handler 190Hobart Spool-Gun 100Lincoln 225 ACMiller & Pipeliner HoodDewalt 14" Chopsaw, GrindersHarris O/AVictor TorchCustom Built O/A CartCustom Welding CartHeavy Duty 16 Speed Floor Drill PressPipe-BenderDrill Doctor
Reply:It's a great looking project! You outdid yourself.PlasmaCam CNC cutterLathe and Band SawClamps
Reply:Those are really nice!We have a coaster shortage at home, and your holder is awesome. I think I will give that a try.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Very cool coasters! Like the modern look, sleek and neat. Creative idea!
Reply:Mad Cool Idea FEXAL! A polished finish would really set them off! How about a all polished stainless set for the next one!  Attached ImagesI hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Thanks everyone......Mike...... a stainless set sounds like a great idea............I happen to have an old stainless table top that is about 14 gauge (ish).........That might be just the piece to use........Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
GMT+8, 2025-12-28 17:48 , Processed in 0.241109 second(s), 18 queries .
