king pin extension
发表于 2021-8-31 23:00:14 | 显示全部楼层 |阅读模式
has anyone built their own extension for a shortbed pickup with a 5th wheel hitch on a camper ? any ideas ?MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:Need more information, be specific. Dave J.Last edited by MinnesotaDave; 04-01-2013 at 01:37 PM.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:customer asked me to extend king pin side of hitch on an 84 wilderness camper. he just bought a newer ford 4dr shortbed with a 5.5' bed. sorry but thats all the info i got given to me so far.MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:Just searching, looks like many commercial products are available. Maybe one of these will give you some ideas:https://www.google.com/search?q=king...ient=firefox-aTxDoc's Photos Lincoln SP175 PlusLincoln Power Mig 256Lincoln 250 LX Spool Gun Lincoln Precision Tig 225 Hypertherm 600 KMG 2x72 Belt GrinderBaldor 812RE Grinder
Reply:do some looking, I am pretty sure you can buy exactly what your looking for.
Reply:My camper came that way.  I pull it with the same truck."G"ConductorX - The Volkswright Shophttp://volkswright.blogspot.com/http://bugwerks.blogspot.com/Miller DVI w/Spoolgun - Miller Plasma Cutter
Reply:any clue as to if a 10'' extender would be enuf ? how would one go about figuring this out ?MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:anyone ?MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:You are looking for the measurement that allows the trailer to miss the corner of the truck while turning.Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:In the days before luxury pickup trucks, we saw a Cadillac that had a giant Ugly "U" frame welded over the rear window section to pull his fith wheel in our campground.  One of the scariest looking setups I ever saw.
Reply:Or just do this Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I didn't think I would ever see a worse set up, then MinnesotaDave posts that.  That looks like a 1500Lb dog with a 5000Lb tail!
Reply:That is probably the craziest towing set up I've ever seen. not sure about the roof mount being suiteable to handle the load, but sure makes towing and parking a breeze. lmao. Craziness.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Makes me laugh and shake my head every time I see it Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I was considering this at one point for our fifth wheel. But after reading up on the subject I came to understand the the frames of the camper are made special for the ones with the extended kingpin. Just my 2 cents and why I did not do it. I ended up purchasing a slider fifth wheel hitch.
GMT+8, 2025-12-28 17:48 , Processed in 0.126259 second(s), 18 queries .
