Table top material
发表于 2021-8-31 23:00:14 | 显示全部楼层 |阅读模式
I'm getting ready to build a welding table. My question is, cold rolled or hot rolled for the top.  Advantages and disadvantages of each. I'm fairly new to fabricating things and I'm not sure i know the difference.
Reply:Hot rolled.  Cheaper and the mill scale will prevent splatter from sticking.Syncrowave 300Maxtron 450, S-52E, 30A
Reply:The straightest, thickest piece you can get for the least amount of money is the right one....
Reply:Originally Posted by kazlxThe straightest, thickest piece you can get for the least amount of money is the right one....
Reply:Look for options too.  I bought an entire complete table off CL just for the top and scrapped everything else.  It was a quarter the price of what the steel plate would have been new.
Reply:I would love to have an aluminum top table.
Reply:Originally Posted by VPTI would love to have an aluminum top table.
Reply:One of those nifty blast welded aluminum/steel or stainless plates would be perfect for a table top!
Reply:We have two steel tables that we  cut and attached a piece of roughly 3/16 aluminum sheet to. Works great. All we work with is stainless, so with aluminum we dont have to worry about cross contamination. I'd reccomend it.
Reply:Thanks for the replies. I like the idea of the stronghand tables with the holes for fixturing.  Has anybody built anything like that?  Are slots for fixturing a better idea?
Reply:I found a piece of tread plate 1/2" thick 4'x10' for $125. Would this work if I turned the smooth side up?  It's too big for what I need but I can cut it down.
Reply:Originally Posted by Kyled123I found a piece of tread plate 1/2" thick 4'x10' for $125. Would this work if I turned the smooth side up?  It's too big for what I need but I can cut it down.
Reply:That's a great price but the back side of tread plate isn't smooth.  BUT it might be fairly smooth given the thicness of the plate.  Check it out.Syncrowave 300Maxtron 450, S-52E, 30A
Reply:If you make a stainless top, the dingleballs of spatter will stick to it.---No good deed goes unpunished---
Reply:Don't want no dingle balls!
Reply:Originally Posted by Kyled123Thanks for the replies. I like the idea of the stronghand tables with the holes for fixturing.  Has anybody built anything like that?  Are slots for fixturing a better idea?
GMT+8, 2025-12-28 17:48 , Processed in 0.127801 second(s), 18 queries .
