I'm sure this has been posted on this forum at some point before but I thought u guys might wanna see this process..Stainless hopper 16ga stainless Aluminum backing for the corners Inside gets welded What it looks like after weldingNext post is the grinding and polishing
Reply:Grinding processAfter grinding with 80grit 80grit with DynabradeThen another step scotch Brite Almost done!!
Reply:Finished Hopper
Reply:Interesting, but even with a chunk of aluminum there wouldn't there still be atmosphere on the backside of the joint instead of argon or some sort of coverage?Do you have a better pic of the backside of the weld?
Reply:Originally Posted by VPTInteresting, but even with a chunk of aluminum there wouldn't there still be atmosphere on the backside of the joint instead of argon or some sort of coverage?Do you have a better pic of the backside of the weld?
Reply:I do this as well, its great to prevent warping too. I have a bunch of aluminum in various shapes and sizes that I use exclusively for stainless fabrication. Nice work.
Reply:Originally Posted by VPTInteresting, but even with a chunk of aluminum there wouldn't there still be atmosphere on the backside of the joint instead of argon or some sort of coverage? |
