need help identifying an old lincoln welder
发表于 2021-8-31 23:00:12 | 显示全部楼层 |阅读模式
all i know about it is that it's diesel powered and that's about it.. is she any good? how much she worth? and info would be appreciated
Reply:Well... That would depend. Get the model / serial numbers and go the Lincoln website. There is an area under "Support" that will allow you to read the owners manual. Go to Ebay and enter the info and see if there are some listed.If it runs and welds it is of value. If it doesn't weld then it's worth 15 cents a pound.HoboLincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
Reply:Weldandpower ac/dc. Those were good old machines.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:says weldandpower ACDC right on the front. The code number and serial number are at the top, in the middle of the front panel
Reply:Paid 650.00 for mine.Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:Is this one?http://www.lincolnelectric.com/asset...oln3/IM354.pdfMauricio
Reply:WARNING!! WARNING!! Lincoln made a bunch of Weldanpower AC/DC machines using cheap welded tube material for the slip rings. After a bunch of wear, they BREAK right at the weld and it is completely uneconomical to fix the machine. At that point you THROW IT AWAY. It happened to me. Ouch! I actually was able to get a few bucks for it as scrap, engine, shrouding and all. I recommend you PASS on old Weldanpower AC/DC machines!metalmagpie
Reply:Yes that os an older weldandpower, run away fast.Miller Big 40GMiller HF-251 D High FreqVictor OA Lincoln 135 MigMK 3A CobramaticBridgeport J HeadCronatron OxylanceRadnor ACAG TorchWeldcraft TIG Torches1 blown knee and two 5 Gallon pails away from being a hero.
GMT+8, 2025-12-28 17:56 , Processed in 0.095919 second(s), 18 queries .
