Stainless tig weld critique
发表于 2021-8-31 23:00:09 | 显示全部楼层 |阅读模式
Hi all, could you please critique this weld. It is 11ga. horizontal lap 105amps. Thanks Attached Images
Reply:Looks great, you just need to get a little steadier  seems like you had everything going good , just a little squiggly.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:2nd that......are you left handed or is the part upside down? For stainless I like closer dabs to take advantage of the cooling that takes place when you put the filler in the hot puddle removing heat.......Last edited by B_C; 12-06-2012 at 09:21 PM.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Thanks, yes I'm left handed. I've been trying to pulse with the pedal and move back a little when I dab. I keep on screwing up when I need to reposition as I have a harder time staying steady when I'm constantly sliding.
Reply:The left hand side looks the best of the whole thing. You were fairly consistent up to that little hiccup maybe 1/4 of the way across, then you started increasing your spacing between dips until you made it 1/3rd of the way and lost it at what I'd guess was a restart.Keep at it. You are doing fairly well..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I have to say that one of the things I like about my PrecisionTig is the pulse feature. Once it gets set up right it really helps with your spacing and dabbing. I can't keep a drum beat so I can't keep a consisten tig bead. If you were doing that with just pedal  and doing it all at once, I think you did pretty well.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Anyone ever try using a metronome to help with that?
GMT+8, 2025-12-28 17:56 , Processed in 0.099590 second(s), 18 queries .
