Thin sheet practice
发表于 2021-8-31 23:00:08 | 显示全部楼层 |阅读模式
Ran some beads on some .035 sheet today. After a bit, I decided to give the pulser a try. It seams to hide my lack of talent a bit. Kinda got hung up a bit on the middle bead and my filler hand decide it didn't wanna play. Any advise is appreciated.Tungsten: Still have the 2.4mm CerFiller: 1.6mm ER70-S6Amps: 50Pulse time: .01 secBackground Amps: 20Background time: .02 secAnd I had a fight with the photo editor and lost. Flip your monitor upside down or pretend I'm a lefty.
Reply:Can you get your hands on some thinner filler wire? See if somebody will let you take some 0.035 off of their mig spool.
Reply:Tried some .030 earlier. Total failure. I just couldn't feed it fast enough. Bead turned out wide and sunken. I do believe I have figure out how to get that look though..045 would probably be perfect.NickESAB CaddyTig 2200iPowermax 45MM140 (Sold)
GMT+8, 2025-12-28 17:48 , Processed in 0.110825 second(s), 18 queries .
