Carbon Arcing With a Plasma Cutter
发表于 2021-8-31 23:00:06 | 显示全部楼层 |阅读模式
Stupid question, but why not...hasnt stopped me before!Yesterday I was using my new TD Cutmaster 38 to "clean up" some LandCruiser mounts by gouging/blasting/carving the steel away.  This wasnt cutting, but rather more using the tool like a carbon arc.  Made nice clean results.  Is this appropriate terminology?  Are plasma cutters able to essentially "carbon arc"?  Seems like a VERY different process, but with similiar results.ThermalArc 185MillerMatic 180 w/ AutosetVictor Cutskill Oxy/AcetyleneThermal Dynamics Cutmaster 38and spite!
Reply:Originally Posted by DirtyLittleSecretStupid question, but why not...hasnt stopped me before!Yesterday I was using my new TD Cutmaster 38 to "clean up" some LandCruiser mounts by gouging/blasting/carving the steel away.  This wasnt cutting, but rather more using the tool like a carbon arc.  Made nice clean results.  Is this appropriate terminology?  Are plasma cutters able to essentially "carbon arc"?  Seems like a VERY different process, but with similiar results.
Reply:It's called "plasma arc gouging" (as opposed to "carbon arc gouging") and yes, it is a legitimate use of a plasma cutter.A carbon arc gouging setup can also be used for cutting, in which case it's called "carbon arc cutting."Oxy/fuel cutting is the same way, there's oxy/fuel cutting and there's also oxy/fuel gouging. (Granted oxy/fuel gouging works better when a special tip is used)Visit Tensaiteki.com
Reply:Good information to know!  From what I do know of carbon arc its a VERY similiar process, but different design.I did notice that there was a "sweet spot" for maintaining maximum throw where it seemed to really blast the steel away.  Im amazed at the precision of this tool, and wouldve gotten one immediately if I had only known.There really isnt much material out there regarding the proper use of a plasma cutter (quite minimal without any tricks).Thanks!ThermalArc 185MillerMatic 180 w/ AutosetVictor Cutskill Oxy/AcetyleneThermal Dynamics Cutmaster 38and spite!
Reply:like enlpck said, get the right tips and they last much longer.  Plasma consumables ain't cheap,  which I'm sure you know DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:I dunno if you're buying Miller tips, but a pack of five (5) Thermal Dynamics tips cost me under $8.  Is that considered expensive?  I cant destroy the first tip as is.BTW: what are the differences between gouging tips and drag tips?ThermalArc 185MillerMatic 180 w/ AutosetVictor Cutskill Oxy/AcetyleneThermal Dynamics Cutmaster 38and spite!
Reply:I know where you are coming from DLS. The TD cutmaster series are kicka$$ machines. Consumables are way cheaper and seem to take allot of abuse. Glad to see it all working out for you. Stay Cool.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
GMT+8, 2025-12-28 17:48 , Processed in 0.124152 second(s), 18 queries .
