Pedric bending machine
发表于 2021-8-31 23:00:05 | 显示全部楼层 |阅读模式
I am writing a paper in my high school vocational class and I have to write a paper about welding.  One topic I can't find anything about is a Pedric bending machine.  Any help would be appreciated.
Reply:Are you writing a paper or applying for a job?  Maybe both?A Pedric machine bends pipe.  What more do you need to know?
Reply:Writing a paper about welding but asking about a bender? Odd. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Well, im working on a bender, and its sort of a welding project..  Is used in general fabing up of stuff.  Sure, why not a bender.  When I was studying electronics, I did a paper on gyroscopes..  (Laser gyro's were being experimented with).. Why not do a paper on the history or the AWS?  Sounds like it would fill many pages of material and need the use of several resources.. You could do a paper on the migration from gas welding to arc welding in most industries, and why gas is still used in the aircraft industry... The discovery of tungstens use in TIG.. Advancements in Electrode properties (chemical), Do a book report on 'welding secrets' so we can all try to figure out what the secret is.  101 ways to keep from running a bolt!  LOL.. Good luck man.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Originally Posted by Doolittle "...101 ways to keep from running a bolt!"
Reply:Its ok weldorie, the meeting starts at 8Just in case.. drill a hole, get a bolt and run it through the hole securing with (shudder) a nut (I know, we could just weld the bolt but some people like to use the nut).  Or, better yet, welding the nut securing the nut to keep from another weldor no no, tapping the hole.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Originally Posted by DoolittleIts ok weldorie, the meeting starts at 8Just in case.. drill a hole, get a bolt and run it through the hole securing with (shudder) a nut (I know, we could just weld the bolt but some people like to use the nut).  Or, better yet, welding the nut securing the nut to keep from another weldor no no, tapping the hole.
GMT+8, 2025-12-28 17:48 , Processed in 0.108182 second(s), 18 queries .
