06 Ford GT : Project Silver Bullet
发表于 2021-8-31 22:59:53 | 显示全部楼层 |阅读模式
Customer decided to make a build thread on the Ford GT forum so ill repost for everyone.Let me welcome you all to my 06 Ford GT Project Silver BulletI have been beside myself for the last few months deciding what spin I should be putting on my GT. I have been back and forth with turbo options, clutch options, built motor and even if I should keep the blower or not. I decided that the best option right now is to run the bigger pulley on the blower and get a set of turbos to make my supercharged twin turbo setup come alive. The motor will be built over the winter and game plan is to possibly just run with the twins and remove the blower for a custom intake plenum.I have contacted a local shop called Centerline Motorsports to help me with my Silver Bullet project and these guys seem to be more on board about this car than I am.  I have seen some of their work first hand and I am truly impressed and think these guys are more than fit for this project. These guys keep things truly organized and maintain a clean shop which is key for me, which was a big selling factor on my side. These guys even have their own in house CNC which helps aid in any one off parts they need to produce for the GT.Now that everyone knows the direction I want to take with my GT , I did manage to hit the dyno before I dropped her off. I was really happy with my numbers 632 RWHP and 586 RWTQ, I added the dyno graph so everyone can see how the car performs. The pull was done on a DynoJet and the blower is currently running a 17psi pulley. This graph will help serve as a base for when we compare current setup to the new setup.I will have more updates tomorrow with turbo selection and more project info. here is some pictures and a Video...Last edited by RRebelo; 06-21-2012 at 02:08 AM.CenterLine Motorsports - http://www.facebook.com/pages/Center...89516977767905
Reply:These guys are truly inspirational.I head over to Centerline Motorsports to check on some progress to find them working away. They have removed almost the complete rear of the car to allow the proper access needed.  It’s really still a tight squeeze between the frame and the headers. It seems as if they are ready to move onto the building process of the car which I’m super excited for.The selection of the turbo is a big deciding factor when it comes down to a project like this or any project for that matter. After reviewing a few of the current setups on some of the GTs running around it made the decision somewhat easier to get my optimal setup. I first started with a set of Precision 62-65 turbos which I feel would have worked out great, but then I received a call from Harry at Precision and he sent me a set of 64-66 turbos. I was one of the first people to get my hands on set which is really a great privilege and alongside these turbos I will be running Precision wastegates and Tial BOV.The next step in this build will be the custom set of turbo headers made from Stainless steel 1.750 .065 wall tubing with ½ stainless flanges. The headers should be a nice touch to this setup alongside everything else that must be fabricated to complete this build. I honestly can’t wait to see the end result of all this work getting done on silver bullet, also the first drive should be very interesting.CenterLine Motorsports - http://www.facebook.com/pages/Center...89516977767905
Reply:NICE!  Seen a few Ford GT's at the Texas Mile.  One recently went 250+ mph in the standing mile.
Reply:Precision build a bad azz turbo. I'm planning on a pair of 88mm's for my Hemi duster drag car. If I ever get back to working in it. Can't wait to see how she turns out.Offering CNC Plasma cutting and welding projects.Follow me on facebook https://www.facebook.com/nobigdeal.fabSupport those that support WW.
Reply:Originally Posted by NoBigDeal FabPrecision build a bad azz turbo. I'm planning on a pair of 88mm's for my Hemi duster drag car. If I ever get back to working in it. Can't wait to see how she turns out.
Reply:I have been a YB member for a while (under a diffrent name) there is bad and good about every company out there. When the time comes I'll look at it again. But this is not a precision turbo thread it's about a sweet gt. Thanks for your input. But let's stay on topic.Offering CNC Plasma cutting and welding projects.Follow me on facebook https://www.facebook.com/nobigdeal.fabSupport those that support WW.
Reply:Small update…Header Mug Shot! I’ll get into more detail later once both sides are finished and ready to go.CenterLine Motorsports - http://www.facebook.com/pages/Center...89516977767905
Reply:Just curious, why the large megaphone at the end of the runners?Hobart EZ-Tig newbie.
Reply:Originally Posted by chimmikeJust curious, why the large megaphone at the end of the runners?
Reply:Top 3 of my favorite cars.... Shelby Cobra, Cobra coupe, GT 40.  Not in any order. Just Shelby's. Nothing else. EVER...
Reply:I wouldnt do anything to it, but drive it...  It will probably be worth more in stock form than it would be modded.tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Wow...that car is unreal.  Looking forward to the next update.  Thanks for sharing.
Reply:Awesome, you lucky dog you, GTs are amazing cars.Those headers are sweet.Lookin forward to some updates.
Reply:Do you build the collectors yourself?
Reply:Moving along….One header has almost reached full completion. The collector needs a nice buff like the runners and the springs have to be welded to the collector and runner. They will be running 2 springs on each header for removal purposes. The second header has been all tacked together and ready to be fully welded which is something of an update I plan to have for you guys next.I noticed in a post above I didn’t mention that each header starts with a 1 7/8 tube and then its stepped down to a 1 ¾ tube about 1inch away from the head flange. This was done due to the size of the port.  The header has been fully backpurged and port work has been done after completion of welding all the runners to the head flange. I will get more pictures in the days to come of the port work. They also got around to getting somewhat an idea of turbo placement, which should look reasonably well placed under the clam shell. This placement I feel is ideal for mounting support and also I prefer to see the turbos then to keep them hidden...Anyways I’ll be back soon with more updates…..stay posted!CenterLine Motorsports - http://www.facebook.com/pages/Center...89516977767905
Reply:Delays and progress.So…I know we have been lacking a long needed update, but things have been a bit crazy with my current business Performance Auto Carrier and also with the gents over at Centerline Motorsports. They have been in a hectic state as they have pushed to complete a whole shop move in less than four days. I think it’s a bit crazy that they set a deadline like that for such a big move, but let’s face it they did it… as you can see in the pictures below not only did they move everything into the new shop they also built a new mezzanine. It makes you think sometimes how much you can really get done if you have the dedication to make things happen.Next on the block was trying to get placement of the turbo’s in the rear end of the car. After playing with the idea and contemplating about turbo placement, I decided that I wanted to place the turbo’s lower in the car and in Hines sight keeping the center of gravity in an ideal location. The picture below has brackets (rods + Plates) holding the placement of the turbo and that’s the testing stage before they moved to the next mounting bracket (All Plate) which they were satisfied with and now have it being transformed into a 3D rendering that will be made out of billet aluminum which I will be posting a picture as soon as they release it to me.The header is about 99.9% as all its missing is the tabs and springs going from the collector to the runners.  As we continue along this update you might be thinking to yourself well this car needs a clutch and maybe some wheels well…..you’re in luck. I don’t have any fancy pictures like Centerline or anything as these are 100% cell phone pictures, but I will try and get some better pictures of the wheels once they are on the car. Below is a nice set of I Forged wheels and AP Racing clutch.CenterLine Motorsports - http://www.facebook.com/pages/Center...89516977767905
Reply:Since placement of the turbo’s seem to be 100% where I want them now they have moved forward into creating the air inlet section to be routed into the stock air box which to most may look like a challenging task, but for these guys they just truly create some magic. Here you can see the start of an idea and the final part on the bench, I will try and get a picture of this intake pipe mounted on the turbo to give everyone a better understand on how trick I think this looks. The Complete package starting to take some shape….Seeing the up pipe off the header just gets me excited!As we come to the end of this update I hope that I can bring everyone some more updates quicker as I’m sure everyone is just as excited as I am to see the final product and hear the GT roar to life.Last edited by RRebelo; 08-27-2012 at 06:35 AM.CenterLine Motorsports - http://www.facebook.com/pages/Center...89516977767905
Reply:I managed to get the images of the 3D rendered bracket quicker than expected and as promised here it is. I can’t wait to have this cut out and put onto my car.CenterLine Motorsports - http://www.facebook.com/pages/Center...89516977767905
Reply:Looking pretty sweet!-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:PlacementAs the days go by I get excited to get into the driver seat of my car once again, but also I get sad as fall is upon us now…. I know these things take time and the biggest factor that’s holding this back right now is getting the billet aluminum parts made. The drawings are complete and just waiting to hear on a price for machining time.Also some of you may notice that the transmission mount is bent, these guys will also be fixing that issue. I had to use it as a temporary replacement.The wastegates both setup and ready to get mounted onto the up pipes. The exhaust has been placed together and tack welded into place for fitment and style. The exhaust tips are the only part missing. I honestly think this exhaust setup just looks fantastic and it’s exactly what I asked for. These guys do fantastic work!  On the turbos you can see the air intake pipes taking shape on both sides; these will be routed back into the stock air box.I also drove out my lambo to these guys and started playing around with the idea of getting a twin turbo setup done. I think we shall move onto the lambo once the GT is finished...CenterLine Motorsports - http://www.facebook.com/pages/Center...89516977767905
Reply:Damn dude, that looks amazing.Last edited by sqznby; 09-11-2012 at 05:11 PM.
Reply:Looking good.Do you use filler for these butt welds? also what pulse settings do you use (if at all)?Welding/Fab Pics: www.UtahWeld.com
Reply:I'm planning on a pair of 88mm's for my Hemi duster drag car.
Reply:Originally Posted by MikeGyverLooking good.Do you use filler for these butt welds? also what pulse settings do you use (if at all)?Very nice work.  What is going to control the EFI, motec?Lots of toys.
Reply:sct is what he decided on.CenterLine Motorsports - http://www.facebook.com/pages/Center...89516977767905
Reply:Update!They pulled the transmission cross member out of the car to remove the mount, Along with all this they also got the exhaust tips tacked on to get an idea of how everything will look. They also fabricated the dump tubes and got once side completed and I must say this looks stunning if I say so myself. The way the tubes just interlace together is just indescribable. I hope the billet parts come in this week so the rest of the puzzle is here and ready for the final stages of this build. Once everything is complete and put together I can then send everything out for polishing and ceramic coating.CenterLine Motorsports - http://www.facebook.com/pages/Center...89516977767905
Reply:The ExitCenterLine Motorsports - http://www.facebook.com/pages/Center...89516977767905
Reply:amazing looking.miller syncrowave 250hobart handler 140home made 400 amp engine driven in progress...
Reply:Waiting….Amazing! Is one key word that describes everything in this picture. The new transmission mount that was cut out has been tacked into place with new metal. I’m truly excited and happy how everything is turning out. The heading may seem deceiving, but I’m truly playing a waiting game with the billet parts. I hope they come in by Friday and then these guys can start finish welding. The next move is a big deciding factor for me as I’m stuck in between a rock and a hard place. Let’s just say airbox cooler….CenterLine Motorsports - http://www.facebook.com/pages/Center...89516977767905
Reply:There sure is some action with that stud!
Reply:BILLET!!Finally got the billet brackets in, which look amazing! I’m glad were past this stage now and moving forward now the up pipes, exhaust and dumps can all be welded. I still haven’t decided what I plan to do beyond this point….if I should do a water to air setup or not…it’s a really hard choice, but I know I have to make up my mind soon as things progress. CenterLine Motorsports - http://www.facebook.com/pages/Center...89516977767905
Reply:Long Time! Let Me Leave You With This!More Pictures In 10 Hours! CenterLine Motorsports - http://www.facebook.com/pages/Center...89516977767905
Reply:Excellent craftsmanship. That's a shoe horn job of note and I know a little about this type project. Being a Ford just makes it even better. You did good.
Reply:Originally Posted by RRebeloI managed to get the images of the 3D rendered bracket quicker than expected and as promised here it is. I can’t wait to have this cut out and put onto my car.
Reply:Missing Updates?Well I got something! The car has sort of been pushed to the side with me as I have been super busy with business and other things in life, but I think it's time I get back into it and start making the push. Centerline has been good to me and have been keeping my car safe on the hoist while I have been doing my thing. I'm glad that this hasn’t been an issue for them as they really do good work and I wouldn't want to take my car anywhere else.Pipes are a bit off as the tape came apart and since it was about to come off to be tacked together, but I’m sure you guys get the point here! Clearance is a huge issue and thats why the pie cuts had to be used!CenterLine Motorsports - http://www.facebook.com/pages/Center...89516977767905
Reply:Originally Posted by TIGger305Beautiful work!!! I would love to learn to fabricate setups like what your doing!!!!.,I have a friend that does some of this type of stuff and has me weld it. But not to the extent and detail that you do...AWESOME WORK!!!What CAD program do you use?..I'm looking to learn I'm looking to learn but I want to start with a good program. stick with 1 and learn it. Without switching from one to another.
Reply:Quite a project!Always loved the Ford GT and yours is going to be really special.
Reply:Awesome, centerlines work is incredible.I'm lookin forward to hearing this thing roar.Lets see this GT, post some shots of it
Reply:The engine bay is tight to start with. That is one serious bag of snakes. You're right, they do excellent work. My project is also a twin turbo application (land speed racing) and luckily my units will be far from the engine bay.
Reply:This is, by far, one of the coolest build threads I have seen in a long time.
Reply:Just curious, why the X-pipe after the turbos and so close to the tailpipe anyway?Welding/Fab Pics: www.UtahWeld.com
Reply:gahhhhhh turbos make way better mufflers than mufflers...You can always wash your hands.
Reply:OhmyGod.very nice.JoeMiller 140 Autoset (2010)Miller Syncrowave 250 (1996)
Reply:And She Starts!CenterLine Motorsports - http://www.facebook.com/pages/Center...89516977767905
Reply:Originally Posted by RRebeloAnd She Starts!
GMT+8, 2025-12-28 21:25 , Processed in 0.074684 second(s), 18 queries .
