Gooseneck hitch
发表于 2021-8-31 22:59:53 | 显示全部楼层 |阅读模式
Let me say first and foremost i did not make this, had no part of making this and never would even attempt anything this stupid. I thought everyone new that gooseneck and fifth wheel hitches were all tied into the frame rails and not just bolted to the bed floor. theres some scary things on the road that back yard welders put together. what are yalls thoughts on this setup?
Reply:Well, at least it's going through the "solid steel" cross member.Millermatic 200Hobart Handler 120Victor O/A & Ramco BandsawLincoln 225 ACSnapOn AD HoodMiller XMT304/22AHypertherm Powermax 1650 G3Lincoln Idealarc DC600 w/Extreme 12 VSMiller Digital Elite "Joker"
Reply:lucky its not a diesel and i  think only a 1500 but screw that. the bed rail will crush and watch that thing rattle.
Reply:Things seem to work best when you dont know what you are doing.Thermal Arc 252iHobart StickmateIf you aint burn'n you aint learn'n.
Reply:Some nice looking welds right threw the rust. But really, all of that his weakest point is the welded on ball. Hopefully he doesn't kill anyone else when the trailer crashes threw the back of the cab.
Reply:Originally Posted by Weldkid14Things seem to work best when you dont know what you are doing.
Reply:Scary!
Reply:$20 says there is a 5/8 hole in the top of the gas tank......any takers?Some blue machinesSome red machineslots of heavy steel
Reply:Originally Posted by moparman68$20 says there is a 5/8 hole in the top of the gas tank......any takers?
Reply:My favorite is, " I pulled about 6,000 lbs. with a, on a gooseneck and it wurked fine"Watch out civilization!Some blue machinesSome red machineslots of heavy steel
Reply:Wow......I guess I wasted my money buying an engineered turn over ball and mounting it to the frame. Maybe next time!
Reply:Probably not much worse than most commercial built flatbeds that are sold for mounting on 1 tons.  The hitch pockets on most of them are really pretty lousy.I do see a lot of these that are just bolted to the floor like this.  I wouldn't do it, but some folks do.DOT leaves these guys alone, and if I have one frayed strap, or a cab marker light out, it's a fat ticket for me"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Last shipping wars show one couple was complaining about getting a ticket for a pesky cracked wheel on their max loaded trailer.  Pffft, cracked wheel, its fine yet.
GMT+8, 2025-12-28 19:42 , Processed in 0.098864 second(s), 18 queries .
