small tubing "helping hands" holder
发表于 2021-8-31 22:59:53 | 显示全部楼层 |阅读模式
I always wanted something to help holding small tubing for exhaust projects, and I didn't want to buy one, but rather make one---just for the hell of it. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Nice!Motorboating...in the Cleavage of the Tetons
Reply:I like it - thumbs up Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Pretty slick, thanks for the idea.If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:Good idea!  I have been wanting something for holding pipe together for years now. I didn't want to pay the price for those special super nice but expensive ones. I like this one! Thanks for posting!
Reply:Here are some more shots.  The nice thing about this, is that it can be scaled up to as large as you may like by increasing the sizes appropriately.  This was done with "1/4" hardware, 3/4" square tubing sliced down the middle for the little saddles, 1/8" thick 1/2"wide flat bar.  Total cost about $10 because I had to buy the 3ft flat bar, nuts, lock washers, small metal sleeves, bolts at a local hardware store.  If you have this stuff already or similarly sized materials your cost can end up $0 lol.As you can see, I tacked the bolt that holds the C-arm to the metal sleeve at different positions for each sleeve.  This is so that they are more or less "in-line" with each other, due to one of the V-hinge's leg in front of the other one since they overlap at the bottom wing nut joint.  To make sure I could get tubes perfectly in-line with each other, the hole in the tube "saddle" that the bolt passes through, is drilled out larger than the 1/4" bolt that goes through it--this is to allow for wiggle-room.Last edited by Oscar; 04-10-2013 at 12:51 AM. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
GMT+8, 2025-12-28 19:42 , Processed in 0.070697 second(s), 18 queries .
