Discovered something about my Dynasty today that made me understand what happened......When you make changes in the settings you can do a Factory Default recovery to put all the settings back if you get the thing too screwed up and lose your way......What I didn't know was you have to select a memory (9) of them...I assumed that reset would reset the whole machine........WRONG...It only resets the memory you select before the reset procedure....I kept having the same problem even after the reset....Tomorrow will be a NEW TEST....I'm learning the hard way.... Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:which dynasty? and how old?Yes in a dynasty 350 and 700 the factory reset is for the active memory only.Leaves the rest of them alone.
Reply:350, newest one Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
