ZANK on Weldingtipsandtricks.com
发表于 2021-8-31 22:59:51 | 显示全部楼层 |阅读模式
ZANKs progress chronicled on WTT.com.   Proof that it's the Indian and not the arrow with tigging.  Congrats ZANK.  Well deserved.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Oh yeah, wait till he gets the Dynasty 280 DX dialed in. I expect it's both the man and the machine. Zap won't try a Dynasty, but I only imagine what he could do with one. Though, I fear he'd need a 700 to weld those massive aluminum pieces he works on.
Reply:Awesome Zank, way to go man! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:He's famous!Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Zank is the man!Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Originally Posted by Willie BOh yeah, wait till he gets the Dynasty 280 DX dialed in. I expect it's both the man and the machine. Zap won't try a Dynasty, but I only imagine what he could do with one. Though, I fear he'd need a 700 to weld those massive aluminum pieces he works on.
Reply:I always like stories of people who take less and make something out of it.Mr. HE
Reply:Couple of points...on the simple machines..The 175 is not that great of a machine for thicker aluminum. It's never has been.. The PT 225 has 230 amps AC, and will melt smaller pieces of 3/8 pretty well. Having a bit of adjustment in balance, and the extra amps,duty-cyle is really money well spent. Just don't want rookies to stop on a under powered machine, unless they are only going to weld thin aluminum.. That is something that should be pointed out right up front in the video. Amps, and duty-cycle are very important on the smaller transformer machines when welding AC. I would never buy below a 200 amp machine. It's the magic # as to getting the puddle wet fast. In most cases with a transformer machine.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:Steve,I am ok with the Smaller inverters with 200-220 + amps. It suits my needs fine. Other people would be disappointed on using them on anything over .0250 aluminum. Wave Balance = more time on Electrode - You can adjust freq, and balance farther over then a Transformer machine, so it acts a bit bigger.. So there are reasons to buy machines for more adjustments. Get more AC input Per amp.. in general. The little transformer machines can weld thicker with Preheat, and Helium mixes, but you can't fix the low duty-cycle. It's kind of false economy to buy under powered for your needs. Everybody should weld with a Miller Econotig to see what happens when you try to do too much with too little.. It's almost like look at what my 30 amp plasma can cut.. 1 inch, and it's awesome.. Yea, if you have all day, and want to work the machine to death.. Check out You tube, and Chucky Cheeses  vids for further info...Last edited by Brand X; 09-27-2014 at 01:57 PM.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:I agree Zank does a great job.  I was only bring up points, that was lacking on the video. Not that Jody has not covered it before, and knows all this stuff..Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:getting an online wt&t plug from jody must have made your day. congrats zank!i.u.o.e. # 15queens, ny and sunny fla
Reply:Thanks, fellas! Yeah, totally humbling. Jody is the man. His videos have helped me immensely through this journey. So has everything I've learned here from everyone. The welding community rules.Mike ZanconatoZanconato Custom Cycles @mzank on Instagram
GMT+8, 2025-12-28 19:44 , Processed in 0.073566 second(s), 18 queries .
