查看: 2|回复: 0
2 Wirefeeder 1 power source?
发表于 2021-8-31 22:59:48 | 显示全部楼层 |阅读模式
Could 2 guys run 2 CV wirefeeders off one power source, like a XMT? I understand they would both be running the same volts.
Reply:No..............
Reply:Yes with a lincoln multiweld 350 , they cost around 4000 each.We run 4 packs off  dc 600 as we are short primary power in one shop.
Reply:I've never seen it happen unless you get a machine specifically designed for that
GMT+8, 2025-12-28 19:43 , Processed in 0.103719 second(s), 18 queries .
