Tungsten selection (size) Transformer vs Inverter
发表于 2021-8-31 22:59:48 | 显示全部楼层 |阅读模式
I have noticed that the size selection of tungsten from an inverter machine compared to a transformer is quite different and figured worth sharing for others learning to TIG.  On the inverter I found out (thanks to Shovelon) that u can use a large tungsten, say 1/8" on just about any thickness metal.  Due to the pointed tungsten and very little balling at the end...I had been puzzled by Zapster's use of 1/16 tungsten for relatively hi current welding.    However I discovered that due to the traditional 1 1/2 times the tungsten diameter ball that forms on AC transformers I could not weld anyway near as thin stock as I could on an inverter.  Thus I had to drop down a couple of sizes in electrode...     Seems that some of the reference charts for tig are totally off depending what type of machine they are written for.  Also foe example the Miller tig calculator claims a crazy 1/4" tungsten and filler for 1/2 alunimum tig welding and requires 3 passes.   That is crazy for either machine.   Now I just set the dial at what I think the max current I need will be,  run a few test beads to dial in the pedal sensitivity and current by watching the puddle.   Same thing with the gas. Turn down as much as I can without getting contamination...Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Originally Posted by soutthpawI had been puzzled by Zapster's use of 1/16 tungsten for relatively hi current welding.
Reply:oooh, oooh, Mr. Kotta, Mr. Kotta,I would take those tungstens!Sit down Horshack. Dang sweathogs.RIP.Seriously, if you are offering! I would take em!Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11oooh, oooh, Mr. Kotta, Mr. Kotta,I would take those tungstens!Sit down Horshack. Dang sweathogs.RIP.Seriously, if you are offering! I would take em!
Reply:1/16" is pretty useless for most everything. They really suck to work with compared to 3/32.Welding/Fab Pics: www.UtahWeld.com
Reply:heh,  I thought I read u were using 1/16 a lot,  I am not greedy and have plenty of 1/16 already so I will pass butt thanks for the offer...Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Originally Posted by MikeGyver1/16" is pretty useless for most everything. They really suck to work with compared to 3/32.
Reply:Originally Posted by BCTimberwolfIt's amazing for welding up fuselages out of .5" 4130 .025" wall tube.
Reply:Bump!Question: Inverter machine, DC only, so TIGging steel & SS. Rank beginner. Don't want to invest in a stack of tungsten. Mostly for learning at first, maybe 1/4" down to sheet... probably not Zaps' aluminum foil any time soon, though...3/32?
Reply:Originally Posted by keithwinsBump!Question: Inverter machine, DC only, so TIGging steel & SS. Rank beginner. Don't want to invest in a stack of tungsten. Mostly for learning at first, maybe 1/4" down to sheet... probably not Zaps' aluminum foil any time soon, though...3/32?
Reply:I use 3/32 red (2% thor) for 75% of my dc tig work. I use 1/16 red for the other 25% of my dc tig work.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Cool, thanks all.I've heard good things about the rare earth options... I know they are non-traditional... Any opinions? I realize they are different by manufacturer, so I guess that enters into it.K
Reply:Originally Posted by keithwinsCool, thanks all.I've heard good things about the rare earth options... I know they are non-traditional... Any opinions? I realize they are different by manufacturer, so I guess that enters into it.K
Reply:I use 3/32 1.5% lanthanated (1.5% is gold). I own a thermal arc 185amp inverter..tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:I am using thoriated .040 and 1/16 on down to 16ga up to 1/8" steel. Haven't even tried the 3/32" yet. I used 3/32 on 1/4" plate on the limited intro I got at the local Votec.Any thoughts on matching tungsten size to material vs amps for the transformer machines? I'm limited on the tapped voltage down to 35A on the Lincoln.I just ordered some lanathanted to try it here:https://weldingsupply.securesites.ne...F:OR:terms::PNThe prices are good, especially on house brand filler rod, but they are a bit high on the shipping. Attached ImagesLast edited by jtcnj; 12-14-2012 at 06:33 PM.Lincoln AC/DC 225/125 and WP17. 75A AC is for pipe thawing!HH 140 - new addtion 9/2012.I didn't agree, but hoped for Hope and Change.I got change for myself and my family: for the worse.This is the reality of: Barackalypse Now. Again.
GMT+8, 2025-12-28 19:43 , Processed in 0.070167 second(s), 18 queries .
