Cheapest Machine to run 5/32
发表于 2021-8-31 22:59:37 | 显示全部楼层 |阅读模式
What would be the cheapest machine to practice running a 7018 5/32 electrode?orWhat would be the minimum voltage/amperage specs to run a 7018 5/32 electrode? Also I would like the machine to have an A/C, D/C feature. I'm going to be practicing for a test.Thanks for your help, joshLast edited by josh930; 05-14-2007 at 10:40 PM.
Reply:A used A/C buzz box.  Less than $100.A/C D/C Used less than $300.220vWhat are you doing that requires 5/32?  I'd guess you will need minimum 150amps.
Reply:If you are practicing proper 7018, you'll need the 240V DC models.  If you buy new, you can't beat the Hobart Stickmate LX for a basic rod burner.
Reply:Originally Posted by MAC702If you are practicing proper 7018, you'll need the 240V DC models.  If you buy new, you can't beat the Hobart Stickmate LX for a basic rod burner.
GMT+8, 2025-12-28 19:42 , Processed in 0.101842 second(s), 18 queries .
