Tube mitering
发表于 2021-8-31 22:59:15 | 显示全部楼层 |阅读模式
What is the best way to mitre tubes for bicycle frames?
Reply:do you mean notching??  for a miter your best bet is a bandsaw or chopsawalso, Please fill in your location!!StangnetShop Full Of Stuff. Joey
Reply:You need a tubing notcher. You can buy cheap ones at HF which is fine for hobby building. If you plan to manufacture bicycles then you will need a much more powerful notcher.
Reply:The cheap way to do it is a hole saw style notcher- HF, or maybe a step up to the old joint jigger- www.dalewilch.comthis style uses a hole saw. the holes saws wear out, but are easy to find.Next step up goes up quite a bit in price- mittler bros and others make either milling machine style notchers, or belt sander style notchers- both run from 2 grand to 5 grand, but are designed for production work.www.mittlerbros.comlike anything else, you gets what you pays for.
Reply:Here a link for a free program for doing that:http://www.ihpva.org/people/tstrike/...ng/tubemit.htm
Reply:You need to look at theses sites:http://metalgeek.com/cgi-system/php5...atic/cope.pcgiframeforum.netA man who can't weld is as poorly educated as a woman who can't sew
Reply:May be:  http://snip.awardspace.com/
GMT+8, 2025-12-28 19:34 , Processed in 0.114782 second(s), 18 queries .
