L-tec Plasma Cutter Help
发表于 2021-8-31 22:59:11 | 显示全部楼层 |阅读模式
Hey! I just picked Up an L-tec Cutmate 20 It seems to power up ok But It needs the torch repaired I'm missing the torch Head and Consumables It looks like an Esab pt31 would fit but None of the local shops have a pt31 torch in stock Does anyone Have any info or spare parts for this Cutter ?Or Does someone need a power supply for their Torch ?Thanks!
Reply:Never heard of L-tec. Try a search on here and then your preferred internet search engine. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Hey dank11,L-Tec is superb equipment as I have used several models of MIG, TIG & one of their Plasma Welders. They were bought out several years ago by Linde, and then ESAB took over the entire L-Tec & Linde line. Your best bet would go to ESAB's website or Google "L-TEC Equipment". you may find some suppliers listed that still have OEM parts. Good luck....DennyComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:Hey dank11,Just spotted an ESAB PT-31XL torch on E-Bay. It is item #110128848277. It has an opening bid of $19.99 and there are no bids at present. You may get a real bargain.....DennyComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:Hey! I found It But the number is 110128848227Your number took me to a Wedding Dress Thanks!
Reply:I have an L-tec 30 amp transformer plasma cutter.  It must weigh 200 or so pounds.  I can buy consumables at the local welding supply.  They do still make the PT-31 and PT-31XL torch.  I can get you part #s if you want.  I copied the page out of the catalog.  It claims ratings for 3/8, but I can do a better cut on 3/8 with a torch.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by David RI have an L-tec 30 amp transformer plasma cutter.  It must weigh 200 or so pounds.  I can buy consumables at the local welding supply.  They do still make the PT-31 and PT-31XL torch.  I can get you part #s if you want.  I copied the page out of the catalog.  It claims ratings for 3/8, but I can do a better cut on 3/8 with a torch.David
Reply:Originally Posted by dank11Hey! I found It But the number is 110128848227Your number took me to a Wedding Dress Thanks!
GMT+8, 2025-12-28 19:41 , Processed in 0.076746 second(s), 18 queries .
