Fluor looking for welders in Texas
发表于 2021-8-31 22:59:09 | 显示全部楼层 |阅读模式
Ran across this on LinkedIn today as I have a connection with a recruiter that works there.  In case it helps anyone I am reposting here.  https://image-store.slidesharecdn.co...-original.jpegMiller Multimatic 255
Reply:Fluor is a big company. They do a lot of work in the northern Alberta Canada oil sands industry as well.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Am curious.  Please school me on this.  We don't use the term 'combo welders' around here.  What does it mean?  that a welder can handle multiple procedures (tig, stick, mig, ms, ss) or that he does his own fitting and welding?  Who does the heavy rigging?
Reply:In the lower 48 a combo welder is typically someone capable of TIG and Stick welding pressure pipe.  Fitting pipe may or may not be a part of the job as well; it changes from job to job.  Larger projects typically have dedicated fitters, riggers, and millwrights.  Small jobs the welder often wears a lot of different hats. Originally Posted by OldSparksAm curious.  Please school me on this.  We don't use the term 'combo welders' around here.  What does it mean?  that a welder can handle multiple procedures (tig, stick, mig, ms, ss) or that he does his own fitting and welding?  Who does the heavy rigging?
Reply:Thanks A DAB....normal call out here would be either pressure stick welder or tig welder with the expectation that the latter would be qualified to fill/cap with stick if need be.
Reply:As I have mentioned in previous posts, combo welders are in great demand down here on the Gulf Coast.Go South!
Reply:Wonder why they're having trouble manning that job? Been seeing them advertise for at least 6 months.
Reply:Originally Posted by TimmyTIGWonder why they're having trouble manning that job? Been seeing them advertise for at least 6 months.
Reply:This morning I saw a neighbor who works for Fluor.  He said they are super busy, but that they're always looking for weldors.
Reply:better up the pay, then
Reply:Originally Posted by TimmyTIGbetter up the pay, then
Reply:$40 an hour should bring them in. That's where it's headed anyway. Shutdown season just started. I recently saw a job advertised in Alabama for just that amount.
Reply:Originally Posted by TimmyTIG$40 an hour should bring them in. That's where it's headed anyway. Shutdown season just started. I recently saw a job advertised in Alabama for just that amount.
GMT+8, 2025-12-28 19:42 , Processed in 0.078969 second(s), 18 queries .
