heat tint on stainless.........
发表于 2021-8-31 22:59:06 | 显示全部楼层 |阅读模式
Anyway to remove it without burnishing or wire wheeling? Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Yes, you can use a pickling acid, but be very careful it burns like hell, find out some details here http://www.stainlesspickling.co.uk/d...nghandbook.pdf
Reply:I used acid and a battery charger ~15 amps. Wrap a copper plate with cotton, dip this in acid, connect the battery charger like a welding machine, and rub on the welds. Not sure polarity, but it works really quick, makes the acid go much faster, but etches the metal a slight bit more.Constant Current Weldor.
Reply:last time i was at the lws i saw a contraption for removing heat tint from welded products. it was the size of a small toaster and had a price tag of 400. i don't know anymore about it.i.u.o.e. # 15queens, ny and sunny fla
GMT+8, 2025-12-28 19:42 , Processed in 0.101044 second(s), 18 queries .
