Komatsu hd325 side boards
发表于 2021-8-31 22:59:05 | 显示全部楼层 |阅读模式
This weeks project is adding side boards to a pair of shiny new haul truck bodies. Fitting each board takes about two hours, they "may require field trimming" according to the manufacture, they all arrived with a curve in them so they had to be persuaded into place with a 3 ton come-a-long and 20 pound sledge. Welded with .045 lincoln outershield and 1/8 7018
Reply:Those are big trucks! where do you work, at a mine?
Reply:What no paint ? all those smoke stainsBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Steel arrived today for the fish plates
Reply:Cut angles and holes for plug welds Bottom gets 6" stitch welds 3 passes each,top gets welded in 6" passes when those are done the spaces in between the stitches get filled in all 3 passes Heres the top all done One side all done 3 more to go
Reply:Be careful all that extra weight may putt that truck over its max gvw
Reply:Originally Posted by killdozerd11What no paint ? all those smoke stains
Reply:Originally Posted by kaldBe careful all that extra weight may putt that truck over its max gvw
Reply:i love working on haul trucks... yeah i'm also curious were you work? its all easy money.. great looking welds to..
Reply:wait, I am a dummy. Why didn't the manufacturer MAKE it with sideboards? Why didn't the customer order the bed with sideboards? Your work is cool. Dream job for me. I wanna work in a shop!Nice postLincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:the fish plates you used is that hardox or a AR plate? the truck looks like a cat 777?
Reply:Great example of why I love suitcase feeders. They're so much more, "mobile". Nice work. You get all the fun jobs!"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:I work at  a one of the biggest Komatsu dealerships in the northeast. You can't actually order the truck from komatsu with sideboards so we had to order,fit and weld them. We installed them in order to raise the capacity of the truck from 35 tons to 45 tons. The fish plates are made from regular old hot rolled steel 3/4" thick, sales manager didn't want to spend the money for any AR plate or strips on the sides,so in 6 months I'll probably have pictures of me carbon arcing the plates off. The suitcase wire feeder has been critical on this job I'm almost 3 times faster than the other welder using SMAW, it's portability is going to be key as the next set of plates has to be welded in while the body is on the truck.
Reply:Gawd it'd be nice to be able to run Outershield.Outside without any way to cut the wind it's a no-go though  I'm stuck with Innershield.  It's slow, and messy.  You simply can't run the wire fast enough to outperform stick..035 Innershield NR-211 can run at about 16v, 100-110ipm max, and it's a slow go  Push it any higher, and you get real bad porosity issues. Stepping up to a larger dia wire doesn't really do much better.  Max I can really run is .045 with my power supply (Ranger GXT), could maybe go up one dia more, but I'd be stuck somewhere in the mid range for .068. Plus the stuff isn't Charpy rated, or seismic rated.  Brittle stuff not really suitable for anything running on the road."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammGawd it'd be nice to be able to run Outershield.Outside without any way to cut the wind it's a no-go though  I'm stuck with Innershield.  It's slow, and messy.  You simply can't run the wire fast enough to outperform stick..035 Innershield NR-211 can run at about 16v, 100-110ipm max, and it's a slow go  Push it any higher, and you get real bad porosity issues. Stepping up to a larger dia wire doesn't really do much better.  Max I can really run is .045 with my power supply (Ranger GXT), could maybe go up one dia more, but I'd be stuck somewhere in the mid range for .068. Plus the stuff isn't Charpy rated, or seismic rated.  Brittle stuff not really suitable for anything running on the road.
Reply:I welded a whole Komatsu together......all by my self!!! Attached Images200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:Originally Posted by bert the welderI welded a whole Komatsu together......all by my self!!!
Reply:Hey Fireman,I got rid of my LN25, which I miss, but I can't tell what you are using for a power supply. What is it? I had to use my Ranger 9.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11Hey Fireman,I got rid of my LN25, which I miss, but I can't tell what you are using for a power supply. What is it? I had to use my Ranger 9.
Reply:You nailed that one BertBobcat is a little small don't you thinkBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:True enough, it's not a haul truck without side boards on it. I don't even think the 960 haulpacks come with them. Nice job,Matt
Reply:Great job!  The welds are strong and clean. That will be a super haul truck. Well done!
GMT+8, 2025-12-28 19:43 , Processed in 0.107468 second(s), 18 queries .
