line boring job front end on a atf
发表于 2021-8-31 22:59:03 | 显示全部楼层 |阅读模式
From today Little slop in hole it a 3.000 pin hole bored .670 before it cleaned up.Setup bar Bore it out Truck end with power unitWeld in bushing little final fitting in morning and all done.
Reply:Nice repair. Did you build the line bore or it a factory setup?
Reply:No we built it in house mostly from the scrap out of the steel rack. Having a machine shop has its benefits. Thanks
Reply:The homemade line bore in sweet! nice repair
Reply:Originally Posted by dppmfgNo we built it in house mostly from the scrap out of the steel rack. Having a machine shop has its benefits. Thanks
Reply:Originally Posted by forhireAlright... tell us more. Is that a standard hydraulic motor? I've been thinking of building my own.
Reply:I'd like to see more pics / information of the line bore as well!Andrew
Reply:What in the wide wide world of sports did they do to that axle???    Lemme guess, chained a big rock to it & tried to pull it out of the ground...   I like the home made bar setup.If you get a lot of your first fixes, keep an eye out for one of the smaller rottler or van norman automotive cylinder bars. They also work pretty good for driving a line boring bar as long as the holes aren't too large.Nice work;Matt
Reply:WOW!Nice Tool!Apparently built by Craftsmen, Not Engineers with AutoCad!Seems too simple to work, but apparently works quite well!Nice Job!
Reply:what is the housing material?  cast? of the repairOf all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
GMT+8, 2025-12-28 19:42 , Processed in 0.106930 second(s), 18 queries .
