304L to 17-4ph
发表于 2021-8-31 22:59:02 | 显示全部楼层 |阅读模式
just a hose end assembly I work on among the other stuff at work 304L welded to 17-4 PH Filler Hastelloy-W dia 0.020 gas 25 % helium 75% argon 1/16 thorated sharpened to point AMPS a lil pedal set on ticklemachine Miller syncrowave 250Testing after weld out PT,Xray, and hydrotest to 12k psi and nitrogen gas pressure test to 5k psi Attached ImagesMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:looks good to me.  what's it for?
Reply:An excellent weld smaller than I could see to weld correctly I had to blow the pic up just to see the weld on my screen..."Amps set on tickle" - now that's funny Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by oxy moronlooks good to me.  what's it for?
GMT+8, 2025-12-28 19:42 , Processed in 0.094096 second(s), 18 queries .
