Hot Start And TIG ???
发表于 2021-8-31 22:59:00 | 显示全部楼层 |阅读模式
Anyone use the "Hot Start" mode on their TA 185 in the TIG mode ???
Reply:I never noticed it working in the tig mode but I just keep it off/down all the way. You do have hot start built into the foot pedal though.
Reply:Unless there is a settings for Staring Amps it most likely only pertains to STICK  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Originally Posted by Jay O You do have hot start built into the foot pedal though.
Reply:I use it.  Generally set it to 20 amps for aluminum.  Gives you a increased burst when you first hit the pedal, helps with getting a fast puddle.You could probably just weld with a higher amp setting, but then pedal movement will cause a wider swing in amps and less control.Last edited by Drf255; 12-23-2012 at 07:28 AM.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Zapster uses hot start with his TIG.  I have not needed it myself though hot start is awesome for stick welding... works really well if u ever have to use Aluminum stick electrodes...Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I have an older TA LT-300 (mid 90s DC inverter) I use the hot start function with tig because i use a torch switch in leiu of a foot pedal. I make a lot of short tacks using 2t function on s/s sheet metal and I like to move quickly to aviod heat distortion/discoloration. I noticed I was able to establish a puddle more quickly and noticed a much more consistant heat signature on the back side. Also seems to help with higher amp starts with larger dia tungstens, but I have much less exp with that. As stated above the pedal overrides the hot start. -Rob
GMT+8, 2025-12-28 19:43 , Processed in 0.099511 second(s), 18 queries .
