Setting differences between .035 and .045 hardwire?
发表于 2021-8-31 22:58:35 | 显示全部楼层 |阅读模式
I noticed back in school when using .035 hardwire, the wire speed had to be up around 400-600 depending on metal thickness.  Now that I've had some time in the field I'm currently using .045 hardwire, and my settings are usually between 20V/250WS-27V-350WS. Nothing really higher than 350WS.  Is this because of the bigger wire that the wire speed doesn't need to as high as when using a thinner wire? In school I was using an XMT 350, now I'm using an older Invertec machine, I think 350 Pro.
Reply:Anybody?
Reply:There's more mass in an inch of.045 than .035 so less wire speed I'd needed for the same voltage.
GMT+8, 2025-12-28 21:49 , Processed in 0.112078 second(s), 18 queries .
