Tread Brite Poster frame..........
发表于 2021-8-31 22:58:21 | 显示全部楼层 |阅读模式
I had a left over piece of 1/16" TB from a panel on my cabinet build........ the piece was decent sized but I decided to use it to make a frame.....I got a Sterret poster that I originally just put on the wall with push pins........ I instantly knew that wouldn't last........ the look was just not complete.....So I grabbed my Lowes saw (made to cut wood.... but works well on Aluminum) and cut the strips......Then welded them together and put the poster back on the wall.......Here are some pics of a quick job on a free poster........... Attached ImagesPrecision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:I like that Fexal! The perfect frame for a pic in a garage."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:So, when are you getting that plasma cutter? As I found out, they're great for making scrap! As usual, lookin' good.  When a welder tells you to "stick it", what do they really mean?"In a time of universal deceit, telling the truth is a revolutionary act." - George Orwell
Reply:Gives it the perfect touch!       WSMiller Thunderboldt AC DC Miller 211 MIGSmith O/A torches Torches and GaugesRyobi chop saw
Reply:Nice job! . . . Looks great! Hobart Handler 190Hobart Spool-Gun 100Lincoln 225 ACMiller & Pipeliner HoodDewalt 14" Chopsaw, GrindersHarris O/AVictor TorchCustom Built O/A CartCustom Welding CartHeavy Duty 16 Speed Floor Drill PressPipe-BenderDrill Doctor
GMT+8, 2025-12-29 01:12 , Processed in 0.098553 second(s), 18 queries .
