I wanted some custom clamps made to tidy up the hydraulic hoses on my press. I spent a portion of my day making die set. The pics show the die set, then forming a clamp in progress, and finally the finished product (minus bolt hole). The clamps are 304 stainless 1/8" thick, by 3/4" wide. Attached ImagesMy name's not Jim....
Reply:More pics... Attached ImagesMy name's not Jim....
Reply:That's slick.
Reply:I may just steal that idea. I like it.
Reply:Great job as always. Lot of work went into that.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:A good idea that is well executed Very nice.Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Nice looking die. Thanks for sharing.Is that material being formed annealed 304 stainless?I'll bet forming it like that really work-hardens it.
Reply:Very nice. As for the bolt holes, I find these handy. Attached Images"USMCPOP" First-born son: KIA Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Is there a way that you could add a punch to the die? So you only have the one operation ?
Reply:Nice........real nice....
Reply:Wow! WSMiller Thunderboldt AC DC Miller 211 MIGSmith O/A torches Torches and GaugesRyobi chop saw
Reply:That is great. One of the reasons I joined welding web is to learn all this great stuff from you folks. Excellent job. richey
Reply:Boostinjdm, I was thinking of this thread while making some hydraulic fitting hangers today. Not my design... a copy of the customer's part. Hydraulic is actually a misnomer as they are dry lines used to shield electrical cables to the fixed line release on a helicopter. It would have been a lot faster to press them out. Like Fnord5, I too would like to know if your planning on adding a punch mechanism to to it all in one shot. Attached Images
Reply:I'm not going to mess with adding a punch for the hole. I can cut to length, form, and drill a clamp in a couple minutes. The material just says 304L on it. I don't know if it is annealed or not, but I chose the stainless for 3 reasons. I had it on hand. It will hold it's shape. It won't rust.My name's not Jim....
Reply:I use these when I make trailers with hydraulics. I also used them for the custom transmission cooler I built. I ran hardlines for it. These clamps worked awesomely.The base is steel. I weld on the base and then just screw the top down on them. They are sized perfectly for each hose size. But your project is way cooler. I can't say I made my clamps! Very nice die set bro!Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:I looked at those clamps, but they wouldn't fit where I wanted to clamp the hoses. Plus, they're kinda ugly....My name's not Jim....
Reply:Nice job!But did you copy me? lolThis side of the car I just welded 3 different size tubes together for the different lines then drilled threw holes between the tubes. I welded together about a foot of tubing and then cut out the small clamp sections.This side was two tubes welded to a square stock in the middle same deal, about a foot of length welded up and then cut up into clamps.Last edited by VPT; 04-25-2013 at 08:41 AM.
Reply:Hey not Jim... I like the way your thinker works! Slick idea, thanks for sharingNickoliIf I can't fix it, Its probably not broke.... Yeah Right!~ Damn I let out the factory installed smoke again ! ~
Reply:Nice job! Hobart Handler 190Hobart Spool-Gun 100Lincoln 225 ACMiller & Pipeliner HoodDewalt 14" Chopsaw, GrindersHarris O/AVictor TorchCustom Built O/A CartCustom Welding CartHeavy Duty 16 Speed Floor Drill PressPipe-BenderDrill Doctor
Reply:Nice work, man.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:304L is typically sold in the annealed state but will harden with cold forming. |
