Keggle and burner stand
发表于 2021-8-31 22:58:14 | 显示全部楼层 |阅读模式
I made this setup for my buddy. Its a keg converted to brewing tank and banjo burner stand. First pic shows a coupler that I put on the lathe to cut a shoulder. Each fitting is tigged with my diversion at 65 amps thoriated tungsten 1/16 and dcen with argon at 15. The shoulder protrudes inside for an autologous seal weld later. This seals the seam inside for sanitary reasons. Dedicated argon backpurge was used. The stand /burner table in 1.5 in sq steel .065 tube, 1.5 in angle migged with mm211. Burner cowel is 16 ga steel bent with my break press. Cuts made with pm30 plasma. My "e" swoosh on the cowl. Sent from my SCH-I605 using Tapatalk 2 Attached ImagesMiller diversion 165Miller mig 211Hypertherm pm 30Milwaukee 6230 14 inch chop sawMd 45 mag drill (RIP; fell on its head)New MD 45! Thanks to the esposa!Finally got an O/A setup
Reply:This banjo burner puts out over 200 k btu. And the cowl blocks the wind. The feet of the burner table are flat plates / skids. The grate we made to support the tank is 1/2 in by 1 in. Crs in the shape of a # sign. The tank sports a thermometer and a ss valve and a fluid level sight glass. We boiled 12 gallons from cold tap temp in about 45 min. My bro in law uses this setup to make beer. I weld and fabricate. He does the brewing. We both drink the beer. Any improvement ideas welcome!Sent from my SCH-I605 using Tapatalk 2 Attached ImagesMiller diversion 165Miller mig 211Hypertherm pm 30Milwaukee 6230 14 inch chop sawMd 45 mag drill (RIP; fell on its head)New MD 45! Thanks to the esposa!Finally got an O/A setup
Reply:Great job Elliot.  Did you use any purging or Solar B inside the Keggle?TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:thanks! I built a little "house of argon" and stuck it to the inside of the kettle around the hole / coupler i was working on. I used foil heat resistant tape. Then i ran a hose of argon from a seperate bottle / regulator and set it on 5-10 ish. I put a foil plug in the coupler so all the argon didnt escape.Miller diversion 165Miller mig 211Hypertherm pm 30Milwaukee 6230 14 inch chop sawMd 45 mag drill (RIP; fell on its head)New MD 45! Thanks to the esposa!Finally got an O/A setup
GMT+8, 2025-12-28 21:47 , Processed in 0.098436 second(s), 18 queries .
