TA 185 Error Codes ???
发表于 2021-8-31 22:58:14 | 显示全部楼层 |阅读模式
I got an error code on my new TA 185 the other day. Was an easy fix. I had too long a ground lead..........went to a shorter lead and all is well.Does getting an error code do anything harmful to the machine.........or..........is this just the machines way of telling you that something is wrong ???
Reply:just the machine telling you something is not correct with the machine.tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
GMT+8, 2025-12-28 21:24 , Processed in 0.107069 second(s), 18 queries .
