Who has had a chance to weld a lot with both of these guns and how did you like them? Price and ease of getting parts and how well they welded? I'm wanting to get a millermatic 252 and I have only welded very little with the 30A and well liked it but wasn't long enough to really get a good feel for it. I have welded with the PrinceXL push pull gun just not the Prince XL spoolgun. I know it was a very light gun but there isn't much pricing online and what I did find was pretty high. I personally wasn't happy with the princeXL push pull, it wasn't very reliable lots of hickups everyday trying to weld with it although i was using a 50 ft+whip but I do like that it is very light.Miller 30A I don't think will be a problem getting parts and the price is very good on it but weighs more.I tried the search but couldn't find much on the princeXL and not wanting to totally rule it out yet.Please tell me how you feel about these two guns??ThanksChris
Reply:I have owned both. My preference is the Prince xl. I found the princess has a little smaller handle, which made it easier to hold for me. Down side. Parts are not stocked at most lws.So you have to keep your own inventory. There are no discounts when you order direct from MK.. Its been a long time but back in the day on a 250X the wire speed would only run at half speed. That was the reason for buying a 30A. Didn't like the removal little cover where the drive rollers are. There is no cover on the cables on a 30A. We're currently using XR aluma pro guns. There are some days I still like my Prince Xl spool gun.
Reply:Originally Posted by boatbuilderI have owned both. My preference is the Prince xl. I found the princess has a little smaller handle, which made it easier to hold for me. Down side. Parts are not stocked at most lws.So you have to keep your own inventory. There are no discounts when you order direct from MK.. Its been a long time but back in the day on a 250X the wire speed would only run at half speed. That was the reason for buying a 30A. Didn't like the removal little cover where the drive rollers are. There is no cover on the cables on a 30A. We're currently using XR aluma pro guns. There are some days I still like my Prince Xl spool gun.
Reply:i like the prince XL spool gun but not the push pull. the balance is weird on the push pull setup For a push pull i would rather have a cobra gun.the 30A isn't a bad setup but its not the cats pajamas. I actually liked the spoolmatic 3 better.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:watch e bay. I have bought 25 ft'ers for $500. some of them have been like new. You can buy an extension cable for the control wires and splice in your ow power and gaswelderbobSound Marine aluminum boats
Reply:Originally Posted by boatbuilderwatch e bay. I have bought 25 ft'ers for $500. some of them have been like new. You can buy an extension cable for the control wires and splice in your ow power and gaswelderbobSound Marine aluminum boats |
