TIG Welding Brass ???
发表于 2021-8-31 22:58:11 | 显示全部楼层 |阅读模式
I need to fuse weld some 1/4 plate brass............anything I need to know???
Reply:You might want to braze it instead of tigging it.http://www.weldingtipsandtricks.com/tig-weld-brass.htmlLast edited by Kelvin; 01-04-2013 at 06:15 PM.
Reply:What brass alloy is it. and what is the application?Miller Trailblazer 280 ntS 22 p 12 suitcase wire feeder Miller high frequency box dynasty 200 Millermatic 252 Millermatic 211 Miller XMT 300 Miller spectrum 2050 plasma cutter Cutmaster 42 plasma cutter. Miller dynasty 350
Reply:i've had good success using 12 ga copper wire as filler . weld was much cleaner than tigging Harris phos-bronze brazing rod . keep the heat down to avoid boiling off the zinc in the base metal  and fouling the weld with sulphur .
Reply:Originally Posted by tnmgcarbidei've had good success using 12 ga copper wire as filler . weld was much cleaner than tigging Harris phos-bronze brazing rod . keep the heat down to avoid boiling off the zinc in the base metal  and fouling the weld with sulphur .
Reply:I am making a angle for a ground block for several of my TIG welders......loong story !I decided to try copper instead. This is the first time I TIG welded copper. I used some #10 wire as filler and it welded up fine.....takes a lot of amps though.Thanx for all the help!!!
GMT+8, 2025-12-28 21:47 , Processed in 0.175661 second(s), 18 queries .
