I want know what you guys run on your syncrowaves, what gauge wire from the panel to the outlet, what gauge from machine to plug, three or single phase and what breaker.
Reply:You will find what you need here http://www.millerwelds.com/om/o353u_mil.pdf on 3-10www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:single phase, i ran #4 copper from the panel to the outlet because i had the #4 handy. the machine cord is #6 SO cord about 10' long and i'm using a 60 amp breaker. yes i know it's smaller than called for but there was a big difference in price so i figured i'd give it a try and have never had any issue with the 60 amp. when i initially set the machine up, i cranked it all the way up and with a water cooled torch started wailing on some 1/2" aluminum plate...i couldn't trip the breaker so i figured it was OK as i never run the machine that hard anyhow
Reply:Mine is set up on single phase, 100amp breaker, and I believe #6 wire from the machine to the breaker, with an isolated ground.
Reply:3 phase is not an option on the synchroEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge |
