plasma cutter needs
发表于 2021-8-31 22:58:08 | 显示全部楼层 |阅读模式
I am purchasing a cutmaster 38 in the near future and between the Miller and Thermadyne web pages I can't completely discern if I need to buy an air compressor or not. Does the cutmaster have an integral compressor or will I need to purchase one? If I need to purchase one, is a particular brand better than another? Thanks in advance, jwr2200
Reply:i think you will need a compressor also you will need filters or the air dryer option to keep your air moisture free as for the compressor there are a ton out there it also depends on what kind of cutting you plan on doing.  you want to have a compressor that will keep up with the amount of air your using the dealer should be able to give you some more suggestions350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Originally Posted by jwr2200I am purchasing a cutmaster 38 in the near future and between the Miller and Thermadyne web pages I can't completely discern if I need to buy an air compressor or not. Does the cutmaster have an integral compressor or will I need to purchase one? If I need to purchase one, is a particular brand better than another? Thanks in advance, jwr2200
GMT+8, 2025-12-28 21:47 , Processed in 0.071419 second(s), 18 queries .
