045 fluxcore 3g
发表于 2021-8-31 22:58:01 | 显示全部楼层 |阅读模式
I am a MIG welder at the moment but I previously was fluxcore (preferred career) and I have a new interview/weld test tomorrow and it is with 045 fluxcore 3g weld 1 pass. Should be pretty easy. I was just curious on the settings most of you would use for this because i have never used 045 fluxcore I have always 1/16 or 3/32. Again I need to know what settings would be best used and maybe some techniques most of you would use for the vertical up.! Thanks! I am nervous
Reply:I can't help you with settings. I just turn dials until I'm happy. With dual shield or self shielded wire I build a shelf first, then point the gun slightly down. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
GMT+8, 2025-12-28 21:47 , Processed in 0.096036 second(s), 18 queries .
