Multi-cart build/welding practice
发表于 2021-8-31 22:58:00 | 显示全部楼层 |阅读模式
Been at this thing here for a bit now, my creative side kinda sucks sometime until I see it. But really wanna learn this welding/fab trade & apply that to some chassis fab in the future. Build: mostly 1/4 angle I've collected, reused a dolly & reinforced the bottom to hold both tanks, reused dolly axle & welded that up for rear wheel setup. Waiting on expanded steel for bottom & top layers. Attached ImagesI make eyeglasses by Day  N let the sparks fly at Night...Miller digital eliteDiversion 165Millermatic 211 w/spool gunSpectrum 375Buildpro 1/2 table w/fixtures08 F250 Powerstroke
Reply:Mig welds seem to be coming out thick & ugly... Gun angle or arc length too long I'm guessing. On flat plate I seem to be uniform & not over sized.Mm211 w/auto set & inside chart, c25 mix around 25cf, .030 wire. Attached ImagesI make eyeglasses by Day  N let the sparks fly at Night...Miller digital eliteDiversion 165Millermatic 211 w/spool gunSpectrum 375Buildpro 1/2 table w/fixtures08 F250 Powerstroke
Reply:Over sized mig weld Attached ImagesI make eyeglasses by Day  N let the sparks fly at Night...Miller digital eliteDiversion 165Millermatic 211 w/spool gunSpectrum 375Buildpro 1/2 table w/fixtures08 F250 Powerstroke
Reply:Bead looks better? Attached ImagesI make eyeglasses by Day  N let the sparks fly at Night...Miller digital eliteDiversion 165Millermatic 211 w/spool gunSpectrum 375Buildpro 1/2 table w/fixtures08 F250 Powerstroke
Reply:The cart Attached ImagesI make eyeglasses by Day  N let the sparks fly at Night...Miller digital eliteDiversion 165Millermatic 211 w/spool gunSpectrum 375Buildpro 1/2 table w/fixtures08 F250 Powerstroke
Reply:Need to weld the tank rack up & expanded steel for bottom & top layers. Attached ImagesI make eyeglasses by Day  N let the sparks fly at Night...Miller digital eliteDiversion 165Millermatic 211 w/spool gunSpectrum 375Buildpro 1/2 table w/fixtures08 F250 Powerstroke
Reply:Looking good
Reply:nice so far.Can't wait to see the finished product.
Reply:More pics Attached ImagesI make eyeglasses by Day  N let the sparks fly at Night...Miller digital eliteDiversion 165Millermatic 211 w/spool gunSpectrum 375Buildpro 1/2 table w/fixtures08 F250 Powerstroke
Reply:Tig welds Attached ImagesI make eyeglasses by Day  N let the sparks fly at Night...Miller digital eliteDiversion 165Millermatic 211 w/spool gunSpectrum 375Buildpro 1/2 table w/fixtures08 F250 Powerstroke
Reply:More tig welds Attached ImagesI make eyeglasses by Day  N let the sparks fly at Night...Miller digital eliteDiversion 165Millermatic 211 w/spool gunSpectrum 375Buildpro 1/2 table w/fixtures08 F250 Powerstroke
Reply:Bk side tig welds Attached ImagesI make eyeglasses by Day  N let the sparks fly at Night...Miller digital eliteDiversion 165Millermatic 211 w/spool gunSpectrum 375Buildpro 1/2 table w/fixtures08 F250 Powerstroke
Reply:Can't stay straight it seems sometimes, then my consistency goes... We'll keep at it Attached ImagesI make eyeglasses by Day  N let the sparks fly at Night...Miller digital eliteDiversion 165Millermatic 211 w/spool gunSpectrum 375Buildpro 1/2 table w/fixtures08 F250 Powerstroke
Reply:Well after a few design flaws I think I've finally got it standing... Original design the wheels couldn't handle load, 2nd attempt (4) swivel wheel were used cause unit to tip back due to tank weight -vs- wheel position. (I'm not much of the designer it seems, works out better once I can see it) ANY GOOD DESIGN PROGRAMS YOU ALL USE? Still needs paint & a few more additions I think. All put together from scrap I've collected since doing this welding thing. Mig & tig used here, pretty much 1/8 - 1/4 angle & tubing used. Attached ImagesI make eyeglasses by Day  N let the sparks fly at Night...Miller digital eliteDiversion 165Millermatic 211 w/spool gunSpectrum 375Buildpro 1/2 table w/fixtures08 F250 Powerstroke
Reply:I seen this on a web site, keeps these angle grinders organized. Attached ImagesI make eyeglasses by Day  N let the sparks fly at Night...Miller digital eliteDiversion 165Millermatic 211 w/spool gunSpectrum 375Buildpro 1/2 table w/fixtures08 F250 Powerstroke
Reply:Tank mount was done a little too high... Comments/critiques welcome. Attached ImagesI make eyeglasses by Day  N let the sparks fly at Night...Miller digital eliteDiversion 165Millermatic 211 w/spool gunSpectrum 375Buildpro 1/2 table w/fixtures08 F250 Powerstroke
Reply:Not bad at all from my stand point. Will   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Nice job! . . . It looks great! Hobart Handler 190Hobart Spool-Gun 100Lincoln 225 ACMiller & Pipeliner HoodDewalt 14" Chopsaw, GrindersHarris O/AVictor TorchCustom Built O/A CartCustom Welding CartHeavy Duty 16 Speed Floor Drill PressPipe-BenderDrill Doctor
Reply:Originally Posted by FabNit2weldiTTank mount was done a little too high... Comments/critiques welcome.
Reply:Nice job!    WSMiller Thunderboldt AC DC Miller 211 MIGSmith O/A torches Torches and GaugesRyobi chop saw
GMT+8, 2025-12-29 02:59 , Processed in 0.099022 second(s), 18 queries .
