monel 400 welded to Monel 400
发表于 2021-8-31 22:57:59 | 显示全部楼层 |阅读模式
material : Monel 400 schedule 40 flange to Crimp socket Filler : 0.045 Rn60Gas : 25% helium 75% argon . Both UHPAmps panel set on 100 Amps on the Syncowave 250 amp control pedal joint design: PP .020 from Id with max being 0.030 from idmaterial prep : electropolished before weld out Position : 5g Attached ImagesLast edited by WeldorWes; 04-24-2013 at 01:06 AM.Miller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Talk to me about the Monel.Tell me about the discoloration. Is that normal? Is it lacking shielding? I know not of what you speak. Never touched that stuff.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Discoloration is normal alot of it is the Helium leaving behind stuffthat is with a number 7 gas lens Puddle is sluggish welds similar to inconel parts get passivated IIRC electropolished after weldout will post a pic in a few out it passivated after weldoutLast edited by WeldorWes; 04-24-2013 at 01:42 AM.Miller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:here is the same part after a sixty second electropolish/ Passivation Attached ImagesMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Originally Posted by Joker11Talk to me about the Monel.Tell me about the discoloration. Is that normal? Is it lacking shielding? I know not of what you speak. Never touched that stuff.
Reply:monel has a very low rate of expansion among other things.   Makes it good in things that will need to be rigid over large thermal swings.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Sounds like a good candidate for building a swimming pool heater with! I hear that the good ones are made out of titanium.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11Sounds like a good candidate for building a swimming pool heater with! I hear that the good ones are made out of titanium.
GMT+8, 2025-12-28 21:47 , Processed in 0.096337 second(s), 18 queries .
