Modifying My Truck Body, Making It More Welder Friendly
发表于 2021-8-31 22:57:57 | 显示全部楼层 |阅读模式
I always hated the half a$$ed lead tree that came with my truck and climbing in and out to set up the torches was getting old. Today I did an early job, and started in on cutting up the body on my truck.This is where the torches are now, pain in the a$$ to set up and break down, and I dont like the weight distribution on the truck.Here is the crap I cut off, notice the old lead tree the guy I bought the truck from made, I have always hated it.....New spot cut out for my torch bottlesTime to cut the channel iron for the frame and go weld it up, more pix laterDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Sitting. Waiting.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Hurry up man, some of us are hold our breath. and as you would know, we get a little heavy winded at times.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Are you even QUALIFIED to do this type of work?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterAre you even QUALIFIED to do this type of work?...zap!
Reply:I'm assuming you got a house on fire, why aren't you here yet emergency call the second you finished the cutting.I'm always amazed at how bad the underbodies of the northern trucks are from the salt.
Reply:tozzi, does your truck have the 6.5? and do you know what gear ratios are in the axles? just curious how the truck does with all the weight. I am about to set up my 95 dually with a flat bed and welder etc.
Reply:Yes a 6.5 turd with whatever the diesel only rear was, I weigh 16,000 and this truck is a slug. I need to drop in a Cummins, or go to a real medium duty truck.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by kaldI'm assuming you got a house on fire, why aren't you here yet emergency call the second you finished the cutting.I'm always amazed at how bad the underbodies of the northern trucks are from the salt.
Reply:Tag for more pics.
Reply:well I passed out waiting for more pictures, and when I come too there still aren't more. come on!There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Here are a few moreI love the tri standAlmost thereI need a few pieces of plate and some red paintI am just going to throw down what I have for under the bottles and attach the hold downs that I already have. I will be making new hold downs one of these days.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Wow looks like a snake den all those cables etc running every which wayBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Originally Posted by TozziWeldingYes a 6.5 turd with whatever the diesel only rear was, I weigh 16,000 and this truck is a slug. I need to drop in a Cummins, or go to a real medium duty truck.
Reply:It is not totally done, but painted and ready to use in the morning. I know the red is not the same as the rest of the truck and I don't care.Cold galvy primerRed paintAnd the tank hold downsDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:I am not going to see this in the news anytime soon am I??...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Pardon me, if i tought from looking at the pics only, that the welder was aging and building a stairway to his deck....;o) Good work!
Reply:I am ready to go tomorrow morningDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Glad to see you didn't catch the truck on fire"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammGlad to see you didn't catch the truck on fire
Reply:Originally Posted by zapsterI am not going to see this in the news anytime soon am I??...zap!
Reply:A work truck will always be a work truck no matter if the paint matches or not.Nice job Tozzi.   Do you plan on redoing the fender opening and putting in an inner fender to keep crude off the tanks?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55A work truck will always be a work truck no matter if the paint matches or not.Nice job Tozzi.   Do you plan on redoing the fender opening and putting in an inner fender to keep crude off the tanks?
Reply:Looks nice!  I would put some plate in from that tire otherwise the tanks are gonna be sitting mud.  Your are right though, you do need a medium duty with all that gear.  I gave up an f550 and went to c7500 back in 03 for a flat bed application and have never looked back.  I will say when you have to buy tires it's a shock though.  6ea  295-75-22.5" ~3k and those were chicom tires.Nice job, I like it, very accessible. I can't tell, can you reach to put the regs on the oxy without a step or climbing? And what if you made a horizontal mount, on top, just to the right of the welder, facing side to side, to store your CO2 cyls? I know you have to stand them up to use them, but just for storage???edit- Looking again, you can probably get one up there. Unless you went two high......."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:I am going to put some 8" sched 10 pipe pieces inside the body behind the torch bottles and they can just drop in those, maybe put a pinch bolt in them for good measure.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
GMT+8, 2025-12-28 21:47 , Processed in 0.097944 second(s), 18 queries .
